help cect A706 PINOUT can Someone Help Cert A706 Pinout? |
Dear Friend, There are different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en |
in a face its written N70I but back on battery it show cert A706 |
and connector type is? |
cable for n95 from china it fit |
There are different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name and "cable for n95 from china it fit" |
5 Attachment(s) this is picture of it |
is it 1x18 pin connector? |
yes,i think 1x18 pin connector |
hello! check with multimeter if your phone's pin1 is GND. if yes- try folowing pinout: http:///vbb/showpo...7&postcount=87 |
no 17 and 18 pin gnd........ |
hello mr. sonumobilewala! do you need pinout for cect a706? is it MT62xx MCU baseD? |
plz help me |
hello! i can only advice how to find pinout by multimeter. set it to voltage measuring mode. one probe set to some grounded phone part, with another touch one by one all phone pins if you see voltage 2,7-2,9 volts- those are tx/rx |
