help : china n82 2sim pin out org post: http:///vbb/showth...08#post3338108 Quote:
http://img146.imageshack.us/img146/9187/n822simox7.jpg http://img146.imageshack.us/img146/3...simbackbm9.jpg http://img355.imageshack.us/img355/6...simrxtxpx2.jpg http://img370.imageshack.us/img370/5...imsoketcs5.jpg |
ou must use Rx_A and Tx_A test points |
Any another ideas ? |
hello! please double check your wiring. Tx_a goes to pin 3 of RJ45 (b0x) Rx_a must go to pin 2 of Rj45 (box) GND must go to pin 8 of rj45 (box port) |
[img=http://img292.imageshack.us/img292/6039/tjagez1.th.jpg] this photo t-jag for infinity box |
did u tried switching Rx and TX???? |
Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: EVEN25_HW Software version: E558_JQ3F8.V60.01.1_ Software date: 2006.06.14 Barcode: E55803230001403 imei: 3525230***** Finished, time used: 42 sec Power off phone now ! |
reading ok but not read and write second area heLp me pLs |
nitialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 error: wrong answer: C3 error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 22 sec As you see box red the phone, but 2nd cpu area gave the error i wrote below.. Is it a common problem ? How can i make connection with 2nd area ?? |
use lower speed. Thanks |
ty bro and i am tried Low speed but and i see this error for 2nd area imei repair What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "imei repair" procedure again If imei can't be detected: 1. make "complete" ffs format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "imei repair" procedure again If imei can't be detected: read flash and send to support: [email protected] heLp me pLs thanks |
imei repair can be done with mode 3 on second cpu. thanks |
hey bro mode 3 and aLL prog normal done . but no change imei . no repair. no writing new imei why why why probLem infinity team HELM ME PLSSSSSSSSS detecting eeprom/ffs size... eeprom/ffs size: 00080000 ffs chip: 00 eeprom/ffs area: 00000000:00380000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E558AGENT_V60_F1_MT6223S00.01_2_20080205.BIN]]... file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E558AGENT_V60_F1_MT6223S00.01_2_20080205.BIN]_20080526-141627.B0E.bin flash: EC257E25032501:2AEA0000000000 Backup required data Done Patch required data... 4 step(s) required to finalize Patch required data Done Special operation... Special operation Done Write... flash: EC257E25032501:2AEA0000000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 102 sec Remove/Install battery now ! |
