05-24-2008, 00:55 | #1 (permalink) | |
No Life Poster Join Date: Jan 2005 Age: 42
Member: 106391 Status: Offline Thanks Meter: 37 | help : china n82 2sim pin out http:///vbb/showth...08#post3338108 Quote:
05-24-2008, 14:39 | #5 (permalink) | |
Member: 106391 Status: Offline Thanks Meter: 37 | Quote:
[img=http://img292.imageshack.us/img292/6039/tjagez1.th.jpg] this photo t-jag for infinity box | |
05-24-2008, 14:52 | #6 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Quote:
did u tried switching Rx and TX???? | |
05-24-2008, 15:24 | #8 (permalink) | |
Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: EVEN25_HW Software version: E558_JQ3F8.V60.01.1_ Software date: 2006.06.14 Barcode: E55803230001403 imei: 3525230***** Finished, time used: 42 sec Power off phone now ! | |
05-24-2008, 16:00 | #9 (permalink) | |
05-24-2008, 17:45 | #11 (permalink) |
Member: 106391 Status: Offline Thanks Meter: 37 | nitialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 error: wrong answer: C3 error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 22 sec As you see box red the phone, but 2nd cpu area gave the error i wrote below.. Is it a common problem ? How can i make connection with 2nd area ?? |
05-24-2008, 17:53 | #12 (permalink) | |
No Life Poster Join Date: Sep 2003 Age: 43
Member: 39948 Status: Offline Thanks Meter: 68 | Quote:
use lower speed. Thanks | |
05-24-2008, 20:31 | #13 (permalink) |
Member: 106391 Status: Offline Thanks Meter: 37 | ty bro and i am tried Low speed but and i see this error for 2nd area imei repair What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "imei repair" procedure again If imei can't be detected: 1. make "complete" ffs format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "imei repair" procedure again If imei can't be detected: read flash and send to support: [email protected] heLp me pLs thanks |
05-26-2008, 12:37 | #15 (permalink) |
Member: 106391 Status: Offline Thanks Meter: 37 | hey bro mode 3 and aLL prog normal done . but no change imei . no repair. no writing new imei why why why probLem infinity team HELM ME PLSSSSSSSSS detecting eeprom/ffs size... eeprom/ffs size: 00080000 ffs chip: 00 eeprom/ffs area: 00000000:00380000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E558AGENT_V60_F1_MT6223S00.01_2_20080205.BIN]]... file saved: D:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E558AGENT_V60_F1_MT6223S00.01_2_20080205.BIN]_20080526-141627.B0E.bin flash: EC257E25032501:2AEA0000000000 Backup required data Done Patch required data... 4 step(s) required to finalize Patch required data Done Special operation... Special operation Done Write... flash: EC257E25032501:2AEA0000000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 102 sec Remove/Install battery now ! |
New china 1112,1600 pin out | Shantobhai | Chinese Models & Cloned Phones | 24 | 07-22-2010 06:43 |
Solution : HOW TO FIND PIN OUT in SPD CPU | bestncheap | VE-KING | 21 | 01-02-2009 20:27 |
6300 china phone rm243 pin out please help | ailman_78 | Infinity-Box | 1 | 10-10-2008 16:32 |
China N95 New pin out here!!! | .::skybird::. | Chinese Models & Cloned Phones | 1 | 09-08-2008 09:34 |
pls give me a n98(rh37) 2sim pin out | nishantha | Infinity-Box | 1 | 03-07-2008 13:59 |
