03-06-2017, 13:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Xiaomi ( Hydrogen ) MI MAX MI account remove ( Success Report ) 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8976] ID_BLOCK_S : 0199B653 ID_BLOCK_I : 009B00E1 ID_BLOCK_L : CBB41733B98870235226B2F569D5252A ID_BLOCK_L : 639DD74E81A8BA706FFE1B0E69DD097C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x11 , VENDOR : TOSHIBA , NAME : 032G34 Boot Ok! MIAccount reset passed! Normal reset : > Select "FORCED FIX" or "REPAIR" in FMT settings, press "Format FS / Reset Settings" > PowerOn device and use. IF Device stuck on black screen with cable - use another FMT > Not all devices supported yet! (tested on Hydrogen,Land,Redmi2) Done! Elapsed: 00:00:29 |
The Following 6 Users Say Thank You to srinibas For This Useful Post: |
03-16-2017, 17:10 | #4 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Xiaomi Helium (seems) unsuccessful Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 03131A12 ID_BLOCK_I : 009900E1 ID_BLOCK_L : 0C75D6F4784FB1E4EDE77134A81AE2D5 ID_BLOCK_L : DD1B51F0071630EEE9709194E35B87FA Use CM2 Internal Loader FH_LOAD_CODE : 14 Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! This one [MSM8952] is not supported or what is happening? |
The Following 2 Users Say Thank You to byteforce2016 For This Useful Post: |
01-21-2018, 13:39 | #8 (permalink) |
Freak Poster Join Date: Sep 2016 Location: Rawalpindi
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Hi sir, I have done all as above stated and MI ACCOUNT removed. But when wifi on again its locked. Its MI MAX Hydrogen. MSM8952__Xiaomi__Xiaomi__ANDR_v6.0.1__MI_MAX__hydr ogen__hydrogen Please need help. Thanks Br, Raja |
