08-04-2008, 10:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: CHINA Age: 34
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | Help Dead China After Formet....... New firmware detected: SZMI26_05C_ELIDA_PCB01_GPRS_MT6226_S01.S650D_ELIDA _V1_5.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 2 chip(s)... standard eeprom/ffs offset detected: 00F00000 flash: 01227E22022201:29EA0000000000 checking area[00000000]: 00000000-007FFFFF... flash: 01227E22022201:9D929D00000000 checking area[00800000]: 00000000-007FFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00F00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user HELP HOW CAN I LIVE MY PHONE FLASH FILE IS NOT IN SUPPORTED AREA........I CHACKED IT......... ver. sw1: SZMI26_05C_ELIDA_PCB01_GPRS_MT6226_S01.S650D_ELIDA _V1_5.BIN ver. sw2: S650D_ELIDA_V1.5, 55C3880B BR.DYNET |
The Following User Says Thank You to DYNET For This Useful Post: |
08-04-2008, 14:59 | #2 (permalink) |
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | No................... Not Not Any Solution For Thish China Fone Wfer Is Teem Do Something For Me Plz.... Br.dynet |
08-04-2008, 15:06 | #3 (permalink) | |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Quote:
Read u r message carefully. U got new version. Kindely read full flash of u r set & send this file to [email protected] After that u got any good solution from Infinity team. Post result. | |
The Following User Says Thank You to amol_sm For This Useful Post: |
08-04-2008, 15:42 | #4 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
The Following User Says Thank You to debmobile For This Useful Post: |
08-04-2008, 15:50 | #5 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Every infinity user should first backup full flash when the software says " new firmware detected " before doing any operations. This would help to recover set in case something goes wrong.. |
The Following User Says Thank You to zeel_zeel For This Useful Post: |
08-04-2008, 16:43 | #6 (permalink) |
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | I Am Tooo.......... Dear Friend I Am Old User I Have Many Repaired Chines Phone But In Thish Case Custmer Is Saying For Some Fast Work And After Formet Other Tool ( V-pro) My Set Is Dead In Infinity I Allwayes Take All Back Uo After Thish Msg..... So It You Have This File Pls Send Me I Am In Truble Thank You..... Br.dynet (your Form Friiend) |
08-05-2008, 16:06 | #9 (permalink) |
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | I Need Full Flash File Too.............. If Any Budy Have Plz Send Me .................. Br.dynet |
08-06-2008, 05:48 | #10 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | i don't know what is your's problem? i am allrady post where's the file in support area,plese see pitcher , |
08-06-2008, 06:32 | #11 (permalink) | |
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | ok but .............. Quote:
Phone History... Receved For Restart Problem With Sim ...... Formeted By Other Tool (ve-pro).... I Have Infinity-box But For Custmer Req For Fast Work I Trayed In Ve-pro .... After Formet Set Can't Power On I Trayed Many File From Support..but Still Same..... Now I Neeed Full Flash File.......... Thanks Br.dynet....... | |
08-06-2008, 11:37 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, now your phone can only be repaired by using firmware "SZMI26_05C_ELIDA_PCB01_GPRS_MT6226_S01.S650D_ELID A _V1_5" find same working set on your local market and read out flash. you will be able to use it for repairing your phone. Send your phone backup to [email protected] too, i will upload it to support |
08-19-2008, 00:51 | #13 (permalink) | |
Freak Poster Join Date: Jan 2006
Member: 223770 Status: Offline Thanks Meter: 49 | Quote:
plz help dead china set | asad_nomy7 | Infinity-Box | 7 | 03-28-2008 11:50 |
help ! dead m55 after downgrade | zeynel | E-Gold Based Phones | 4 | 12-23-2004 16:22 |
help dead A55 after attempt to go to c55 | gazza221 | Siemens Hardware Repair Area | 8 | 05-20-2004 02:42 |
HELP! DEAD V50 after downgrading from TEST point. | gsm4dcs | Hardware Repair by brands | 1 | 12-09-2002 02:38 |
help dead c25v61 after wrong unlock | komix | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-26-2001 13:07 |
