12-12-2007, 13:54 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: Flower from Stone Age: 48
Member: 66300 Status: Offline Thanks Meter: 18 | Help with flashing KG130 ==== log opened: [12.12.2007 11:41:42] ==== Application: C:\Program Files\InfinityBox\LGA\LgA.exe Loading data, wait... [Infinity Box] v1.22 S/N: 280D:01xx Wait... Current device: LG KG130 Done COM17 ready Loading file v.02... KG130P40-07-v10a_XXX-XX_MAY-14-2007_code.B1M.bin loaded Loading file v.02... KG130P40-07-v10a_XXX-XX_MAY-14-2007_alchemy.B1P.bin loaded Testing COM17 at 921600... COM17 [VCP0] selected Device: LG KG130 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 3553110130297xx current otp imei: 3553110130297xx file saved: backup_eeprom_3553110130297xx_LG KG130_20071212-114356.B1E.bin ....... version: XXX-XX V10c EUR KG130P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 Write: Alchemy data flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 584 sec Remove/Install battery now ! |
12-12-2007, 16:09 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, As I can understad phone can power-on but problems with LCD. is it right ? If so, please, try to use other flash files, f.e. KG130P40-EEU-V10d-XXX-XX Jun 25 2007 |
Help with flashing U708 and problem with locked files | buramario | Samsung Flashers, Software, Firmware. | 5 | 07-22-2009 10:08 |
please help with flash t230 gdfs with ufs3 | markLEE | Sony Ericsson | 2 | 09-27-2006 20:08 |
help with flashing e800 with ufs please | bawheid | UFS2 + UFS3-Tornadoflasher | 7 | 03-04-2006 14:27 |
Need help with flashing an a927 with chipset type 17 | freedomizer | Motorola P2k | 1 | 04-29-2005 08:18 |
