Old 10-11-2008, 16:15   #1 (permalink)
karikari's Avatar
Member: 390204
Sonork: 100.1592805
Thanks Meter: 138
Thumbs up <<<<<<HELp help.....>>>>>>
please N99 phone code help me...
I have format in safe mode and write imei but still phone code
please team help me....
thanks
Old 10-11-2008, 17:51   #2 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
Flash the phone with the similar version. Check the support site if the same file exist there then download that file and flash the phone and phone code will be reset 100%.
BEST OF LUCK
yawarniazi
The Following User Says Thank You to yawarniazi For This Useful Post:
Old 10-11-2008, 18:25   #3 (permalink)
khadim100's Avatar
Member: 52828
Sonork: KHADIM100
Thanks Meter: 1,212
try complete format method & post results.......
Old 10-13-2008, 11:17   #4 (permalink)
karikari's Avatar
Member: 390204
Sonork: 100.1592805
Thanks Meter: 138
please sir still
see
COM2 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:259C:E8A0
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: D08_THL_F6500_MT6226_V_231.BIN
ver. sw2: V_2.3.1, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 147 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 10-13-2008, 11:20   #5 (permalink)
karikari's Avatar
Member: 390204
Sonork: 100.1592805
Thanks Meter: 138
please look also imei change....
Action: imei
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Hardware version: D8
Software version: V_2.3.1"
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono-CPU
new imei: 3504480.............
imei verified Ok
Finished, time used: 35 sec
Power off phone now !
but still the same phone code...
Old 10-13-2008, 11:33   #6 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
Thanks Meter: 198
try to put 1122 0r put 0000 or 1234 and cheak
Old 10-13-2008, 11:45   #7 (permalink)
karikari's Avatar
Member: 390204
Sonork: 100.1592805
Thanks Meter: 138
[quote=frnd_4_gsm;3741730]try to put 1122 0r put 0000 or 1234 and cheak[/quote
please i have try not working....
thanks
Old 10-13-2008, 11:47   #8 (permalink)
karikari's Avatar
Member: 390204
Sonork: 100.1592805
Thanks Meter: 138
please sir not working
help me ....
thanks
Old 10-13-2008, 12:12   #9 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 434
help me ....
thanks
just simply do this..
BEST OF LUCK
yawarniazi
The Following User Says Thank You to 3stanGsm For This Useful Post:
Old 10-13-2008, 12:31   #10 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
Thanks Meter: 198
before doing flashing backup epprom and flash
and just do as yawarniazi told
The Following User Says Thank You to frnd_4_gsm For This Useful Post:
Old 10-13-2008, 13:57   #11 (permalink)
karikari's Avatar
Member: 390204
Sonork: 100.1592805
Thanks Meter: 138
Please sir can you help me out... with the file...
I'm just new in chaina phones...
please help me...
thanks
Old 10-13-2008, 14:11   #12 (permalink)
SE-THAILAND's Avatar
Member: 10084
Thanks Meter: 283
up load ur backup file.may i can fine pass for u
br
se
Old 10-13-2008, 14:50   #13 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
Thanks Meter: 198
@karikari
first of all download new version of chinese miracle software 2.63
and cheak with these opption user/lock code and repair security
<<<<<<Help me on Diamond>>>>> karikari HTC & PDA WM( With Touchscreen) 1 11-19-2009 18:52
<<<<<6230i big problem...please help..>>>>>> karikari Universalbox 5 09-20-2008 11:16
<<<<<please help me ... V3xx >>>>>> karikari Smart-Clip 1 06-26-2008 01:45
<<<<<<<< dct4 free no dongle >>>>>> gladeo Nokia Multimedia 60 04-29-2004 20:43
Page generated in 0.25239 seconds with 9 queries
