01-16-2008, 21:31 | #1 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 219015 Status: Offline Thanks Meter: 42 | LG-KG195 can't attach |
01-16-2008, 22:11 | #2 (permalink) |
Member: 219015 Status: Offline Thanks Meter: 42 | I find my problem. I have next quastion I press format ffs safe but: COM6 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... chip: 0031:BDC1:E8DE Connecting, wait... error: can't finalize test moide Operation failed ! Finished, time used: 24 sec Remove/Install battery now ! What can I do? |
01-16-2008, 22:33 | #3 (permalink) |
Member: 219015 Status: Offline Thanks Meter: 42 | I flash this phone with repair eeprom from support now phone is formated ffs with safe mode but with errors... COM6 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... chip: 0031:BDC1:E8DE Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7332RU00-001-R1M Version: FP_0620 imei: 13579024681122 connection Ok building list... done items to clear: 188 warning: wrong packet cs <----- warning: wrong packet cs <----- 184 of 188 items cleared building list... done 4 items remains Finished, time used: 70 sec Remove/Install battery now ! phone powered with restart problem ? |
01-16-2008, 23:42 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It's not so important error (in fact it's warning, not error). I am sure that it will be no any problems with phone due to this repaired communication fault. |
01-17-2008, 22:11 | #5 (permalink) | |
Member: 219015 Status: Offline Thanks Meter: 42 | Quote:
1st with communication-outgoing work perfect but can't incoming calls 2nd can't set up time & date, when I enter time&date menu phone is restarting. 3nd when I enter in cantacts menu->search, phone is restarting. How I can repair this problems? | |
01-17-2008, 23:04 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. try to make "complete" format, check phone 2. write "repair eeprom" from support area, check phone if still the same: try to reball Flash/CPU chip and then flash/format phone again (if need). |
03-06-2008, 17:36 | #12 (permalink) |
No Life Poster Join Date: Feb 2008 Location: pakistan Age: 43
Member: 705991 Status: Offline Thanks Meter: 115 | ok infinity client dont give me time so i rtnd the phone thanks client he unlocked his phone manually is it possible or not or any manually codes of thats type of model |
LG KG195 off on LG logo. | amol_sm | Infinity-Box | 9 | 06-22-2008 11:44 |
can't attach a K800. Before was attaching. | monsterpassword | Cruiser Suite | 9 | 05-23-2007 05:43 |
Can't attach LG 3G phones. | Spiralman | Cruiser Suite | 0 | 05-07-2005 17:09 |
cruiser can't attach s700 | Ryu | Cruiser Suite | 0 | 12-26-2004 07:24 |
I can't attach file | hthongvn | Board, Server and Login Problems/Support | 2 | 10-19-2004 21:21 |
