Old 06-15-2016, 11:15   #1 (permalink)
bench betita's Avatar
Member: 580233
Thanks Meter: 27
Help,.how to fix mount error..
can you help me how to solve this problem,, i recive a phone in no menu condition.. ZH&K spark II..
i can't back up the phone, so i try to flash with firmware that some user tested..
also flash with fresh back up still vibrate only after flash
here's my problem...
hope you can help me,. tnx
Old 06-15-2016, 11:16   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 14,688
Hello.
Make FlashIC test first.
The Following User Says Thank You to JayDi For This Useful Post:
Old 06-15-2016, 11:44   #3 (permalink)
Member: 580233
Thanks Meter: 27
Originally Posted by JayDi View Post
Hello.
logs:
Operation : FlashIC ReadOnly/BadBlock Test [ v1.19 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 7 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
Prepare test data ...
Test flow #0 ...
Test flow passed!
Test flow #1 ...
Test flow passed!
Test flow #2 ...
Test flow passed!
Test flow #3 ...
Test flow passed!
Test flow #4 ...
Test flow passed!
Test flow #5 ...
Test flow passed!
Finalize Ok!
Test passed successfully!
Elapsed: 00:00:59
Reconnect Power/Cable!
Old 06-15-2016, 12:16   #4 (permalink)
JayDi's Avatar
Member: 462970
FlashIC is alive.
Are you sure about mobile have only one HW revision and it is compatible with all SW versions? Case as yours normally happen, when device have different HW revisions, which require different FW version.
Old 06-16-2016, 03:06   #5 (permalink)
Member: 580233
Thanks Meter: 27
FlashIC is alive.
it means, the firmware that i used is not compatible with my phone at hand sir?
Old 06-16-2016, 10:39   #6 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,836
Hello,
Yes, try to find other firmware and flash it.
Br.
Infinity Box Support Team.
Old 06-17-2016, 02:38   #7 (permalink)
Member: 580233
Thanks Meter: 27
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
tnx team,, i've got new firmware and its alive now.
The Following 2 Users Say Thank You to bench betita For This Useful Post:
Old 06-18-2016, 04:08   #8 (permalink)
Crazy Poster
Member: 1316900
Sonork: none
Thanks Meter: 25
hello mr.bench betita can u share your firmware i have same problem pls...
The Following 2 Users Say Thank You to d'starter For This Useful Post:
Old 06-18-2016, 04:13   #9 (permalink)
Member: 580233
Thanks Meter: 27
SP7731GEA_scx35_sp7731gea_ts6_xilaida_4.4.2_HYST_T S6_SPARK_II_4P8_V05_20150825_ZH&K_SPARK_II - Download - 4shared
credit to the original owner of the firmware,.. SIR, OXYGEN...
Old 06-18-2016, 04:16   #10 (permalink)
Member: 580233
Thanks Meter: 27
Old 06-18-2016, 04:17   #11 (permalink)
Member: 580233
Thanks Meter: 27
Old 06-18-2016, 04:18   #12 (permalink)
Member: 580233
Thanks Meter: 27
Old 06-18-2016, 04:20   #13 (permalink)
Member: 580233
Thanks Meter: 27
credit to original owner of firmware sir oxygen,...
Old 06-18-2016, 04:22   #14 (permalink)
Member: 580233
Thanks Meter: 27
The Following User Says Thank You to bench betita For This Useful Post:
Old 06-18-2016, 04:29   #15 (permalink)
Crazy Poster
Member: 1316900
Sonork: none
Thanks Meter: 25
thankyou very much sir downloading
The Following User Says Thank You to d'starter For This Useful Post:
Page generated in 0.41032 seconds with 7 queries
