06-03-2009, 22:14 | #1 (permalink) |
Junior Member Join Date: Feb 2008
Member: 697572 Status: Offline Thanks Meter: 2 | help with huawei t208 i try with restore function and then press sp unlock the progrs bar finish sucsessful but when i turn on the phone its the same no signal please help |
06-04-2009, 07:11 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
06-11-2009, 22:09 | #4 (permalink) |
Freak Poster Join Date: May 2006
Member: 285074 Status: Offline Thanks Meter: 20 | THATS IS NOT POSSIBLE... I UNLOCK THIS MODEL WITH INFINITY, AND THE SIGNAL IS OK... I `VE UNLOCK HUAWEI MOVISTRAR FROM GUATEMALA ..AND ALL IS PERFECT. ... FOR UNLOCK THIS MODEL YOU DONT NEED TO FLASH IT...JUST PRESS SP-UNLOCK....ITS ALL YOU HAVE TO DO... MAYBE YOUR MOBILE IS DAMAGED USE CABLE LG017 OR ALC S210 COM14 [VCP0] selected module v1.66 Device: Huawei-T208-HW-A Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T208-HW-A_eeprom-static_20090611-145138.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T208-HW-A_eeprom-security_20090611-145139.B1E.bin reading eeprom-complete... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T208-HW-A_eeprom-complete_20090611-145146.B1E.bin reading additional data... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T208-HW-A_lock-area_20090611-145159.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 52 sec Remove/Install battery now ! |
The Following User Says Thank You to bachatia For This Useful Post: |
10-10-2009, 11:50 | #5 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Cameroon- Bamenda
Member: 69269 Status: Offline Thanks Meter: 175 | when u use unlock method 1 the process went through as if it unlocked but when you insert sim and put on the phone it reads illegal and goes off .and when you take restore method it goes through but still locked. so infinity do something about this pls. |
10-10-2009, 11:51 | #6 (permalink) |
Member: 69269 Status: Offline Thanks Meter: 175 | when u use unlock method 1 the process went through as if it unlocked but when you insert sim and put on the phone it reads illegal and goes off .and when you take restore method it goes through but still locked. so infinity do something about this pls. huawei t208 |
10-10-2009, 22:14 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @abakwa Did you tried to make 112/emergency call without sim card ? What is the results ? |
11-21-2009, 20:16 | #8 (permalink) | |
Member: 697572 Status: Offline Thanks Meter: 2 | Quote:
and if can you can upload to support one generic flashfile that work on 850-1900 brand fine il be so glad thanks wait for answer | |
Help with huawei modem EG162G | rshyam | Dongle Problems (USB-Smart) | 10 | 01-05-2011 21:07 |
Need some help with Huawei E156G usb modem | badboy-uk | Phone Unlocking Codes & Maps | 7 | 01-21-2010 21:14 |
help with huawei e1550 | bigalan2k7 | Phone Unlocking Codes & Maps | 0 | 11-05-2009 20:27 |
plz help with huawei c2605 unlocking | achintya | Various CDMA/TDMA Cell Phones | 1 | 11-05-2009 06:20 |
infinity team help with Huawei T201 | nellabe | Infinity-Box | 4 | 10-15-2008 12:18 |
