Old 09-25-2012, 11:42   #1 (permalink)
Member: 1815867
Exclamation Help with Infinity Box Plus Combo Edition RED
Hi everyone, I've just purchesed an Infinity Box Plus Combo Edition (Color Red) from IP-Mart.com for 300 USD
Now, I was thinking that Infinity will be the best choice to start because I am a new user, so I connected the box to the pc, everything goes fine, all lights work all drivers installed, upgraded dongle and activated the box and the internal pinfinder...
Now it's possibile that do not find any pinout? I was thinking that maybe some china phones do not have the pinout in the cable, so I soldered cables directly on the pcb of the phone, and I've used the rj-45 cable named J-Tag SG-AT106 to connect the box to the cables that I soldered on the pcb of the phone
But with my surprise do not work either! phone receive power and power up too, so I think that voltage is ok, but it seems like that do not read tx or rx
I've even tried to invert tx and rx but still nothing
Am I wrong? Or the box do not work?
Old 09-25-2012, 18:09   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
if you want to test connection with direct cable- you must use Pin 2,3 of box's RJ45 port.
these pins are Tx, Rx. Gnd must be taken from pin 8.
Old 09-25-2012, 19:51   #3 (permalink)
Member: 1815867
So If I want to test the connection with a direct cable I need to crimp the cables that I solderd on the pcb of the phones and make an RJ-45 and putting those cables on 2, 3 and 8 pin of the rj-45
So This will work?
Tomorrow I will test it and post the results, I hope that will work...
Old 10-03-2012, 18:22   #4 (permalink)
Member: 1815867
The my damned box do not work! It's official!
I've tried everything, it seems like that send data but not read!
I mean, I have tried to send AT commands from a Terminal, when I connect on the port of the box the software greatly slow down, for send a command it takes a lot of time!
And in the end, I've tried to make Rj-45 cables, they works but the box still not work
After that I've tried with F-Bus Clap that have an UFS RJ-45 Cable, after set the RJ-45 UFS in pinfinder, I've tried to read but nothing! and another thing, I've tried to connect to my Original Nokia N70 with the adapter P-14F and do not find any PINOUT (and this is impossible, because I have the same USB cable and works!)
What I have to do?? I have spent 300 USD for nothing
Old 10-03-2012, 21:58   #5 (permalink)
Member: 148515
hello!
pinout search work only for certain CPU types, only for serial communication.
mostly for china made phones with MT62xx CPU.
our box does not search and can not use USB communication in any way.
original Nokia CPU is not supported. Even if you see P-14F cable- it is for other china phones, which uses MT62xx inside
Old 10-04-2012, 07:16   #6 (permalink)
Member: 1815867
Yes ok, nokia cpu is not supported...
But what about china phones? do not work!
As I said, I soldered cables on the pcb of the china phone on GND, RX, TX and nothing
Send but not read, what is the problem?
Old 10-04-2012, 20:19   #7 (permalink)
Member: 148515
hello!
are you sure in CPU type used in this phone?
you must correctly select it in pinfinder software.
this is must do in any any existing box.
second: count number of pins and pick correct (suitable) cable for this phone.
thirs: connect power wires (red & black) to battery connector.
press "power On" in pinfinder software and after phone is sourced- try to switch it On.
it must get On.
now you are ready for pinout search. Just press "Find it!" and keep power button pressed all the way while search is in progress.
Please try to follow this tutorial on mt62xx phone
Old 10-05-2012, 07:19   #8 (permalink)
Member: 1815867
Yes I'm sure that the phone mount an MT62XX because I have an USB key (USB to Virtual Com) and after connected the cables on the pcb of the phones, I can comunicate with the phone with AT commands from a Terminal Software and the phone answer fast to those commands and I've made a Full Flash file with MTK Flash Tool
With the box there's nothing to do, when I try to connect to the phone from terminal, after connected to the box port the software slow down and to send an AT command takes a lot of time! (Without answers, even after specified pinout!)
So what can I do?
Old 10-08-2012, 09:56   #9 (permalink)
Member: 1815867
hello!
it must get On.
Any help? I don't know what to do with this box right now! It's useless if I can't flash phones!
Old 10-08-2012, 17:09   #10 (permalink)
Member: 148515
Hello!
i would advise to get phone with mt62xx, contact me over email [email protected] and we will do pinout search step-by-step
Old 10-08-2012, 18:37   #11 (permalink)
Member: 1815867
There's no need anymore! I've find out the problem!!!
The problem was on the usb of my laptop, I don't know why, but anyway I've connected my box to the Home Pc and worked fine even on Win 7!
But now I have a problem flashing a phone with MT6250 chip
Here's the log
COM33 [VCP0] selected
module v4.39
Device _Autodetect MT6250-6253 etc.
Checking data, wait...
Action read flash NAND
interface BROM_DLL_v3.1108.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode currentexpected 3.23.2
CPU 6250CA020100
status FF
bbchip bl ver FE
NOR chip is not detected
NAND chip is not detected
Repeat operation, Press and HOLD Power button more long time !
internal RAM size 00000000
external RAM [HW_RAM_UNKNOWN, CS0] size 00000000
error can not boot device 0C0BS_DA_UNSUPPORTED_BBCHIP
error last error 0C0BS_DA_UNSUPPORTED_BBCHIP
Disconnect...
done
Finished, time used 19 sec
RemoveInstall battery now !
Any help?
Old 10-09-2012, 19:53   #12 (permalink)
Member: 148515
hello!
what problem you have with this phone? Flash ICs are not detected
Old 10-09-2012, 21:47   #13 (permalink)
Member: 1815867
Yes, I can't read the Flash and all the rest, the chip set as you see is MT6250
I don't know why, what can I do to make you understand and solve the problem?
Old 10-11-2012, 10:40   #14 (permalink)
Member: 148515
hello!
does this phone is able to be powered On?
Old 10-11-2012, 14:10   #15 (permalink)
Member: 1815867
Yes it power on, but as I read around... infinity do not support MT6520
I hope they are wrong! and If I can help let me know
P.S. With MTK Flash Tool I've done the full backup succefully of this phone, hope it can help
Page generated in 0.20952 seconds with 8 queries
