Old 07-01-2009, 21:22   #1 (permalink)
Member: 37108
Thanks Meter: 11
help infinity box problem
my box don't work. when I run software all are ok but when i connect phone and after the soft ask power on......nothing?!?! I change box and the phone boot to be unlocked.
this is a log
COM4 [VCP0] selected
module v1.38
Device: LG-KP235
Checking data, wait...
Action: unlock
unlock method: standard
Boot ...
Press and HOLD Power button now
nothing............
when I plug box :TX led is on
After plug phone on rj45 :RX is on
all two are on
I don't know what to do!
Old 07-01-2009, 21:54   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,389
Hello,
If phone can ot be detected by software it's a cable fault. You must double check your cable (probably cable is damaged or wrong) and COM port selection.
Old 07-02-2009, 02:14   #3 (permalink)
Member: 37108
Thanks Meter: 11
I have tested the cable ke500 with another box and it work well. But with my box (serial port or not) when you press and hold power on button the phone go on and the rx led in box go off
Old 07-02-2009, 20:10   #4 (permalink)
Member: 37108
Thanks Meter: 11
Is it some ways to known if the box can be repaired or not (died). Please?
Old 07-02-2009, 20:51   #5 (permalink)
Member: 79418
keyboard top
1.........18
1: Gnd
2: Box Tx/Phone Rx (RJ45 pin-2)
3: Box Rx/Phone Tx (RJ45 pin-3)
5: Gnd
15: Gnd
18: Gnd
Old 07-03-2009, 00:34   #6 (permalink)
Member: 788720
Sonork: 100.1617957
Thanks Meter: 33
I think the fault is in ur software,,,,uninstalled the whole infinity then installed a fresh copy.if still not....then buy a newone with some newcables include...
infinity box problem ATIEFUOR-GSM Infinity-Box 3 11-13-2010 12:02
Infinity box problem please help! bangon Infinity-Box 3 11-04-2008 04:39
Zt-321 Tv Mobile Problem Plese Help Infinity Box Team sujan1050 Infinity-Box 6 03-30-2008 20:20
infinity box problem COMPAQ Infinity-Box 1 04-16-2007 20:18
Infinity box problem sebasto Infinity-Box 1 12-06-2006 07:31
Page generated in 0.29050 seconds with 8 queries
