03-15-2007, 11:43 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: USA
Member: 197538 Status: Offline Thanks Meter: 97 | Help Infinity Cfx65 1) i cant use RJ45 siemens cable with infinity box ...it doesnt recognise and is not compatible ,,,, so i used a com cable sien x55 2). Phone boots ok .. connects ok ,, erases ok ,,, but always write error ,,, Tried almost 20 times but no avail 3). Phone is ok because i wananother flasher flashed this phone perfectly weill and phone alive again but screen blank and sim doesnt seem to be accepted... now need to unlock phone but again same write error.. FLASH LOG Wait... Current device: Siemens-CFX65 Done COM3 ready COM3 selected Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Parameters... Part 1 of 2... In progress... Part 2 of 2... In progress... Finished Remove/Install battery now ! Time used: 38 sec COM3 selected Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Parameters... Part 1 of 2... In progress... Part 2 of 2... In progress... FLASH: 0001:227E Finished Remove/Install battery now ! Time used: 1497 sec Loading... CFX65_10000.1DM.bin Loaded Loading... de-BRDHandel_010_CFX65.1DF.bin Loaded Loading... CFX65_LG1_10.1DP.bin Loaded Loading... CFX65_FileSystem_default_International_07.1DS.bin Loaded COM3 selected Checking data, wait... "Smart write" active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Parameters... Check Parameters Done Check Space... FLASH: 0001:227E Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Firmware try to recovery WRITE error[00::00000000] Infinity team can u please look into this matter as this seems like Infinity error and not phone problem ... Or enlighten me where AM I GOING WRONG ? Thanks Mike |
infinity box not working plz help infinity team | Y2ksalman | Infinity-Box | 21 | 01-18-2011 00:51 |
help infinity team, v670 dead by infinity !! | wejwej | Infinity-Box | 3 | 07-08-2009 09:38 |
.:::::kg275 blinks after flash with infinity help infinity support ::::::. | SAMEER TAHIR | Infinity-Box | 1 | 09-16-2008 20:58 |
cant open infinity shell plz help infinity team | ali_imran | Infinity-Box | 27 | 06-14-2008 20:01 |
i try flyslt100 unlocking with infinity but phone dead plz help infinity team | qaziomer | Infinity-Box | 4 | 03-30-2008 19:43 |
