Help Infinity Team Hello infinity Team I need this file GXQ23C_08A_GEMINI_PCB01_GPRS_MT6223_S00.K2335F_64C _NULL_4L_V01.BIN i download this file from download area after write flash set goes dead plz give me good file Here is log ==== [5/11/2011 3:52:24 PM] ==== COM3 [VCP0] selected module v3.30 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:AF77:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: K2335F_64C_NULL_4L_V01 Version: GXQ23C_08A_GEMINI_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 106 items cleared: 105 of 106 items remains: 0 Finished, time used: 30 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [5/11/2011 3:53:32 PM] ==== COM3 [VCP0] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:AF77:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #04 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #05 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #06 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #07 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2BEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: GXQ23C_08A_GEMINI_PCB01_GPRS_MT6223_S00.K2335F_64C _NULL_4L_V01.BIN project-id: K2335F_64C_NULL_4L_V01, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00700000 standard ffs/eeprom offset confirmed: 00700000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00700000-007FFFFF firmware area: 00000000-006FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25062501:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25062501:2BEA0000000000 Finalization Done Finished, time used: 48 sec Remove/Install battery now ! |
After Loading data, wait... [Infinity Box] Chinese Miracle v3.30 smart-card: connected S/N: ADAC:0116 Wait... Device: Autodetect 6205-6239 NOR Done Loading file v.05... GXQ23C_08A_GEMINI_PCB01_GPRS_MT6223_S00.K2335F_64C _NULL_4L_V01_2010-06-08_8m_En_Fr_Farsi_Ar.B0M.bin loaded usb bootloader (file) is absent rom info ver: 04 sw version: GXQ23C_08A_GEMINI_PCB01_GPRS_MT6223_S00.K2335F_64C _NULL_4L_V01.BIN project-id: K2335F_64C_NULL_4L_V01, 00000000 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: [standard] type (04) TCL-ID is absent firmware date/time: 2010-06-08 19-35 hw1: GXQ23C_08A_GEMINI_HW hw2: GEMINI_B01_GXQ23C_08A_GEMINI ==== [5/11/2011 4:09:37 PM] ==== COM3 [VCP0] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware GXQ23C_08A_GEMINI_PCB01_GPRS_MT6223_S00.K2335F_64C _NULL_4L_V01_2010-06-08_8m_En_Fr_Farsi_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:AF77:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #04 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #05 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #06 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #07 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info: unknown structure: 00 rom info detection finished code offset: 00000000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC257E25062501:2BEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 3 min 32 sec Remove/Install battery now ! |
And after flash set goes dead then i format again ==== [5/11/2011 4:29:03 PM] ==== COM3 [VCP0] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:AF77:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #04 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #05 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #06 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #07 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:2BAA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 it's time to stop: 2B0000AA18B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00700000 standard ffs/eeprom offset confirmed: 00700000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00700000-007FFFFF firmware area: 00000000-006FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25062501:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25062501:2BEA0000000000 Finalization Done Finished, time used: 22 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! But set still Dead plz give me advice urgently |
What was the condition of the phone when you received it? What was the original project id/firmware version? Wr. |
hello! here is another flash file, try it and reply https://rapidshare.com/files/1186099...eeprom.B0M.bin |
