Old 05-11-2011, 12:48   #1 (permalink)
Arain*'s Avatar
Member: 1280695
Sonork: 100.1615740
Thanks Meter: 80
Help Infinity Team
Hello infinity Team I need this file
GXQ23C_08A_GEMINI_PCB01_GPRS_MT6223_S00.K2335F_64C _NULL_4L_V01.BIN
i download this file from download area after write flash set goes dead plz give me good file
Here is log
==== [5/11/2011 3:52:24 PM] ====
COM3 [VCP0] selected
module v3.30
Action: reset settings ("format ffs")
Model: Autodetect 6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:AF77:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: K2335F_64C_NULL_4L_V01
Version: GXQ23C_08A_GEMINI_HW
detecting structure #2...
1 2 3 5 7 8 9 11 13 done
80 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
building list...
done
items to clear: 106
items cleared: 105 of 106
items remains: 0
Finished, time used: 30 sec
Remove/Install battery now !
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== [5/11/2011 3:53:32 PM] ====
module v3.30
Device: Autodetect 6205-6239 NOR
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: EC257E25062501:2BEA0000000000
flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: GXQ23C_08A_GEMINI_PCB01_GPRS_MT6223_S00.K2335F_64C _NULL_4L_V01.BIN
project-id: K2335F_64C_NULL_4L_V01, 00000000
code offset: 00000000
ffs offset/size [01]: 00700000/00100000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00700000
standard ffs/eeprom offset confirmed: 00700000
detecting ffs/eeprom size...
ffs/eeprom size: 00100000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00700000-007FFFFF
firmware area: 00000000-006FFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 48 sec
Old 05-11-2011, 12:49   #2 (permalink)
Arain*'s Avatar
Member: 1280695
Sonork: 100.1615740
Thanks Meter: 80
After
Loading data, wait...
[Infinity Box] Chinese Miracle v3.30
smart-card: connected
S/N: ADAC:0116
Wait...
Done
Loading file v.05...
GXQ23C_08A_GEMINI_PCB01_GPRS_MT6223_S00.K2335F_64C _NULL_4L_V01_2010-06-08_8m_En_Fr_Farsi_Ar.B0M.bin loaded
usb bootloader (file) is absent
rom info ver: 04
TCL-ID is absent
firmware date/time: 2010-06-08 19-35
hw1: GXQ23C_08A_GEMINI_HW
hw2: GEMINI_B01_GXQ23C_08A_GEMINI
==== [5/11/2011 4:09:37 PM] ====
module v3.30
Action: write flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
flash: EC257E25062501:2BAA0000000000
Initialize Done
====> Set baud ...
115200
Set baud Done
rom info: unknown structure: 00
====> Write ...
sec info (fast) detection...
startup code area #1 check...
done
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
Finalization Done
Finished, time used: 3 min 32 sec
Old 05-11-2011, 12:51   #3 (permalink)
Arain*'s Avatar
Member: 1280695
Sonork: 100.1615740
Thanks Meter: 80
And after flash set goes dead then i format again
==== [5/11/2011 4:29:03 PM] ====
module v3.30
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
it's time to stop: 2B0000AA18B09FA518B09FA518B09FA518B09FA518B09FA5
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
standard ffs/eeprom offset assigned: 00700000
ffs/eeprom chip: 00
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 22 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
But set still Dead plz give me advice urgently
Old 05-11-2011, 15:03   #4 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
What was the condition of the phone when you received it?
What was the original project id/firmware version?
Wr.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 05-12-2011, 05:01   #5 (permalink)
Arain*'s Avatar
Member: 1280695
Sonork: 100.1615740
Thanks Meter: 80
Wr.
Phone Was blinking after at logo after power on then i format but not solved then i flash but set goes dead
Old 05-12-2011, 17:47   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
here is another flash file, try it and reply
https://rapidshare.com/files/1186099...eeprom.B0M.bin
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.21590 seconds with 10 queries
