Old 01-03-2009, 21:34   #1 (permalink)
Member: 22284
Thanks Meter: 81
Help infinity team
How can i repair this n78i dual sim ,when switched on stays about 5 second then off,on by itself for about 5 sec ,repeatedly and so on.phone details below
COM7 [VCP0] selected
module v2.72
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:7C03:0006
Connecting, wait...
Release Power button now !
Phone detected, wait...
warning: can't read software version, probably unknown firmware
detecting structure #2...
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs
19 20 21 22 23 24 25 26 27error: detection failed (28 tries), read flash and send to support
connection Ok
building list...
done
no items found
error: operation failed !
Finished, time used: 10 sec
Remove/Install battery now !
module v2.72
Device: Autodetect 6205-6227 NOR
Action: read eeprom
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
boot packet size: 0400
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw 1: PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_YX_XY_ 1_3ML.BIN
ver. sw 2: T228DY.YX.XY.1.3ML, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_YX_XY_ 1_3ML.BIN]...
warning: wrong data size at 0x00E07800, retry...
read error recovered
warning: wrong data size at 0x00E0D400, retry...
warning: wrong data size at 0x00E0DC00, retry...
warning: wrong data size at 0x00E0E000, retry...
warning: wrong data size at 0x00E15400, retry...
warning: wrong data size at 0x00E18C00, retry...
warning: wrong data size at 0x00E19C00, retry...
warning: wrong data size at 0x00E1B000, retry...
warning: wrong data size at 0x00E25C00, retry...
warning: wrong data size at 0x00E28000, retry...
warning: wrong data size at 0x00E2A800, retry...
warning: wrong data size at 0x00E31000, retry...
warning: wrong data size at 0x00E35C00, retry...
warning: wrong data size at 0x00E3C800, retry...
file saved: C:\Documents and Settings\Vin\Desktop\eeprom[PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_YX_XY_ 1_3ML.BIN]_20090103-220059.B0E.bin
Finished, time used: 108 sec
Action: read information
Phone should be Switched ON !
Connecting, wait...
Hardware version: MT6225, E03
Hardware version: PBMTK25_GEMINI_HW
Software version: T228DY.YX.XY.1.3ML"
Software date: 2006.06.14
Barcode: 06100101764 10
imei: 393096028233685
imei: 135790246811220
Finished, time used: 5 sec
Power off phone now !
Files\InfinityBox\ChineseMiracle\flash[PBMTK25_GEMINI_PCB01_GPRS_MT6225_S00.T228DY_YX_XY_ 1_3ML.BIN]_20090103-215235.B0M.bi
Old 01-03-2009, 22:08   #2 (permalink)
Member: 133415
Thanks Meter: 46
Originally Posted by chitawira View Post
how can i repair this n78i dual sim ,when switched on stays about 5 second then off,on by itself for about 5 sec ,repeatedly and so on.phone details below
com7 [vcp0] selected
module v2.72
action: Reset settings
model: Autodetect 6205-6227 nor
checking data, wait...
Phone should be switched off !
Press and hold power button now !
19200 autodetect
initializing [6225:8a03:8a00]...
Cpu: Mt6225
high speed boot on
chip: 0001:7c03:0006
connecting, wait...
Release power button now !
Warning: Can't read software version, probably unknown firmware
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: Wrong packet cs
19 20 21 22 23 24 25 26 27error: Detection failed (28 tries), read flash and send to support
connection ok
building list...
Done
no items found
error: Operation failed !
remove/install battery now !
Com7 [vcp0] selected
module v2.72
device: Autodetect 6205-6227 nor
Advanced flash detection enabled
action: Read eeprom
boot ...
19200 fixed
connecting, wait...
Initializing [6225:8a03:8a00]...
Cpu: Mt6225
high speed boot on
release power button now !
Boot done
initialize ...
Detecting chip #00 in region #00...
Flash: Ec257e25082501:18e59f00000000
flash: Samsung amd/fujitsu std [d 0008x002000 00fex010000 0008x002000] 16mb
initialize done
set baud ...
460800
set baud done
initialize bootcode ...
Initialize bootcode done
check firmware integrity ...
Device parameters autodetection in progress...
it's time to stop: 18f09fe518f09fe518f09fe518f09fe518f09fe518f09fe5
Detection phase #1...
Detect device identification#1 finished
ver. Sw 1: Pbmtk25_gemini_pcb01_gprs_mt6225_s00.t228dy_yx_xy_ 1_3ml.bin
ver. Sw 2: T228dy.yx.xy.1.3ml, 00000000
ffs offset/size: 00e00000/00200000
Warning: Optional information is not found,
Standard eeprom/ffs offset detected: 00e00000
flash: Ec257e25082501:18e59f00000000
checking area [00000000]: 00000000-00ffffff...
Eeprom/ffs found near: 00e00000
Eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00e00000-00ffffff
check firmware integrity done
check firmware content ...
Check firmware content done
backup required data ...
Reading: Eeprom[pbmtk25_gemini_pcb01_gprs_mt6225_s00.t228dy_yx_xy_ 1_3ml.bin]...
Warning: Wrong data size at 0x00e07800, retry...
Read error recovered
warning: Wrong data size at 0x00e0d400, retry...
warning: Wrong data size at 0x00e0dc00, retry...
warning: Wrong data size at 0x00e0e000, retry...
warning: Wrong data size at 0x00e15400, retry...
warning: Wrong data size at 0x00e18c00, retry...
warning: Wrong data size at 0x00e19c00, retry...
warning: Wrong data size at 0x00e1b000, retry...
warning: Wrong data size at 0x00e25c00, retry...
Warning: Wrong data size at 0x00e25c00, retry...
warning: Wrong data size at 0x00e28000, retry...
warning: Wrong data size at 0x00e2a800, retry...
warning: Wrong data size at 0x00e31000, retry...
warning: Wrong data size at 0x00e35c00, retry...
warning: Wrong data size at 0x00e3c800, retry...
File saved: C:\documents and settings\vin\desktop\eeprom[pbmtk25_gemini_pcb01_gprs_mt6225_s00.t228dy_yx_xy_ 1_3ml.bin]_20090103-220059.b0e.bin
finished, time used: 108 sec
Action: Read information
Phone should be switched on !
Connecting, wait...
Hardware version: Mt6225, e03
hardware version: Pbmtk25_gemini_hw
software version: T228dy.yx.xy.1.3ml"
software date: 2006.06.14
barcode: 06100101764 10
finished, time used: 5 sec
power off phone now !
Files\infinitybox\chinesemiracle\flash[pbmtk25_gemini_pcb01_gprs_mt6225_s00.t228dy_yx_xy_ 1_3ml.bin]_20090103-215235.b0m.bi
if your rx tx conection its good tray to check hardware.
Old 01-04-2009, 17:27   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
****o!
make format FFS complete
infinity box not working plz help infinity team Y2ksalman Infinity-Box 21 01-18-2011 00:51
help infinity team, v670 dead by infinity !! wejwej Infinity-Box 3 07-08-2009 09:38
help help infinity team dragon7000 Infinity-Box 0 02-21-2009 17:47
cant open infinity shell plz help infinity team ali_imran Infinity-Box 27 06-14-2008 20:01
i try flyslt100 unlocking with infinity but phone dead plz help infinity team qaziomer Infinity-Box 4 03-30-2008 19:43
Page generated in 0.23454 seconds with 9 queries
