Old 12-14-2009, 05:23   #1 (permalink)
dilshann's Avatar
Member: 1093564
Thanks Meter: 326
Help infinity team.............
COM5 [VCP0] selected
"repair mode" active
Action: format
Device: C155,C156,C157
Checking data, wait...
Connect...
Press and HOLD Power button...
error: initial synchronization failed
Finished, time used: 12 sec
Remove/Install battery now !
Old 12-14-2009, 05:40   #2 (permalink)
Member: 692833
Thanks Meter: 24
check ur cable first sir???
Old 12-14-2009, 05:43   #3 (permalink)
Chennairam's Avatar
Member: 372320
Sonork: 100.113211
Thanks Meter: 2,661
Action: format
Connect...
Check Full Battery And Cable Connector
Old 12-14-2009, 06:26   #4 (permalink)
dilshann's Avatar
Member: 1093564
Thanks Meter: 326
battry & cable is ok......................... i check any phone.. default mode not conecting
this information coming use tp mathod ......................
Old 12-14-2009, 06:38   #5 (permalink)
Member: 288005
Thanks Meter: 13
cek your cable
this
or
this
Old 12-14-2009, 07:09   #6 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
you mean , you are useing Test point method ?
what is problem with this mobile ?
why you use Test point method ?
Faisal_Computer
Old 12-14-2009, 07:44   #7 (permalink)
dilshann's Avatar
Member: 1093564
Thanks Meter: 326
Faisal_Computer
phone coming fualt is ffs format i format phone with infinity but same problam after i flash the phone now is dead phone default mode not conecting
plz solution.......................................... ..............................
Old 12-14-2009, 08:09   #8 (permalink)
Member: 151871
what is exact model ?
and what did you done with it ?
Faisal_Computer
Old 12-20-2009, 16:43   #9 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
In case of any problems with connection (f.e due to damaged software/bootcode) you can use Infinity-Box "RepairModule" to repair this phone.
C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ RepairModule_for_damaged_Moto-c113-c118_c138_c139_c140_etc.htm
Old 06-03-2010, 03:15   #10 (permalink)
ace_venturia's Avatar
Member: 260236
Sonork: 100.1641081
Thanks Meter: 135
Originally Posted by InfinitySupport View Post
Hello,
Repair module not opening??????????
Old 06-04-2010, 11:08   #11 (permalink)
Member: 130995
Hello,
What do you mean ?
Why you can not run RepairModule ?
infinity box not working plz help infinity team Y2ksalman Infinity-Box 21 01-18-2011 00:51
help infinity team, v670 dead by infinity !! wejwej Infinity-Box 3 07-08-2009 09:38
help help infinity team dragon7000 Infinity-Box 0 02-21-2009 17:47
cant open infinity shell plz help infinity team ali_imran Infinity-Box 27 06-14-2008 20:01
i try flyslt100 unlocking with infinity but phone dead plz help infinity team qaziomer Infinity-Box 4 03-30-2008 19:43
Page generated in 0.32554 seconds with 10 queries
