02-28-2010, 21:42 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! must be very rare or new firmware. unfortunately we dont have it in our collection. you can try to search for same working phone on local market. read out full backup and use it for flashing your faulty phone. also i can convert to infinity format BIN file, if you find it. by the way, did you try to solve your problem without flashing, just by format FFS/IMEI restore? |
03-01-2010, 14:16 | #3 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1015645 Status: Offline Thanks Meter: 114 | i have got lg kp320 set when i on mobile hang stand on logo i have whole chip format applied set have dead plz help me infinity team what's problem show this error during flash plz......................... COM4 [VCP0] selected module v3.20 Device: LG-KP320 Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.936.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format (HW_STORAGE_NAND)... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND error: last error: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND Disconnect... done Finished, time used: 1 min 19 sec Remove/Install battery now ! |
03-01-2010, 19:51 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! what was the reason to erase Whole flash chip ?!? now you must flash it back you must open with notepad operation.log file which is located in Chinese Miracle folder. scrool it from up from end and find First operation with this phone. there you will see Original software version. post it here, lets see if we have it on support |
infinity box not working plz help infinity team | Y2ksalman | Infinity-Box | 21 | 01-18-2011 00:51 |
help infinity team, v670 dead by infinity !! | wejwej | Infinity-Box | 3 | 07-08-2009 09:38 |
help help infinity team | dragon7000 | Infinity-Box | 0 | 02-21-2009 17:47 |
cant open infinity shell plz help infinity team | ali_imran | Infinity-Box | 27 | 06-14-2008 20:01 |
i try flyslt100 unlocking with infinity but phone dead plz help infinity team | qaziomer | Infinity-Box | 4 | 03-30-2008 19:43 |
