help infinity team COM5 [VCP0] selected module v3.09 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: write flash "smart write" active write: Firmware BR26_05C_PCB01_GPRS_MT6226_S01.BR26_05_07__Nokia-N95_16m_En_Cn_Ar.B0M_2.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:E824:8858 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: no any expected answer error: no any expected answer : wrong answer after chip id request error: no any expected answer error: no any expected answer : wrong answer after chip cfi request error: no any expected answer : wrong answer after chip id request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged, operation aborted. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 42 sec Remove/Install battery now ! give me solution |
solution is here Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [checked] and try again 4. wrong model selection, try 'NAND' selection |
hello! try speed 115200- if still same error- resolder or heat Flash ic |
