help infinity team in this kind of flash file.... pls if you have this flash files pls upload......... 6300 because i go to support area no one same like this kind of flash file Quote:
thank infinity team pls asap..:D br |
If required file can not be found in support area (please use "search" function in support area first) it will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. Here is an instruction how to make "search" in support area: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files ! |
hello! make search for "HEXING25_GEMINI_PCB01_GPRS_MT6225_S00" and look for similar files |
helo i search many time but no one like this kind of flash files sir because the problem of phone is when you press the number, the number cannot appear on the screen, format FFS,complete mode,safe mode,NO LUCK so i decided to look this kind of flash files,so i try to reprogram...pls help... |
hello! similar flash file can be little different at the file end. for example flashfiles/ChineseMiracle/_MT6225/HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_21__Nokia-6300_16m_En_Ru_Fr_Es_De_Ml_Id_Tr_Farsi_Pt_Cz_Ar.B0 M.bin is also similar to your file, try it |
