03-01-2010, 20:08 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. power Onphone 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone must be powered On) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
@infinityhelp.... | notgood | Infinity-Box | 2 | 05-06-2008 09:21 |
Pleas Infinityhelp There Is No Imei Tab | barkly.kamel | Infinity-Box | 4 | 04-28-2008 17:55 |
InfinityHelp i need your help. need pinouts | IkaMazini | Infinity-Box | 3 | 02-22-2008 20:04 |
A bone with infinityhelp | rampe | Trash | 14 | 01-24-2006 08:40 |
