Old 01-08-2009, 11:57   #1 (permalink)
iwan8818's Avatar
Member: 859702
Sonork: 12345
help infinty box
3. Connect box to PC USB port and select drivers: x:\Program Files\InfinityBox\Drivers\Box\FTDI
my box is infinity box plus..
can u show to me how to install this want...
screen shot or video..
because i can't see this after compelt install egate driver..
Old 01-08-2009, 12:16   #2 (permalink)
iwan8818's Avatar
Member: 859702
Sonork: 12345
and can u show me step by step how to run..
i allready test to read eeprom..
i hold the power buton, phone on..
what must i do?
pleaseee
Old 01-08-2009, 12:16   #3 (permalink)
iwan8818's Avatar
Member: 859702
Sonork: 12345
what must i do?
pleaseee
Old 01-08-2009, 15:36   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
You need to install Drivers first: http://www.infinity-box.biz/index.php?id=support
After Drivers installation you will have a folder with drivers: C:\Program Files\InfinityBox\Drivers\box\FTDI
Then you need to select correct COM port.
Here is an instruction what to do then:
How to write flash (upgrade/downgrade firmware, change language):
1. connect cable
2. run "Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. go to software "Flash" page and load required files
8. press "Write" button and follow instruction given by software
How to unlock (remove sp-lock, provider lock etc.):
1. connect cable
7. go to software "Service" page
8. press "SP-Unlock" button and follow instruction given by software
How to reset/format ffs (reset setting to default values, repair freez/restart etc.):
- at first try to make "safe format" (if this option exist)
- if "safe" option is not wrks try to make "complete" format (if this option exist)
1. connect cable
8. select format mode "safe" or "complete" (if mode is available)
9. press "Reset" or "Format" button and follow instruction given by software
infinty box team please help n-box Infinity-Box 1 04-22-2008 10:02
infinty box help me negm-- Chinese Miracle & PinFinder 1 03-18-2008 22:02
team infinty box plz help me now with c117 amira77 Infinity-Box 5 01-04-2008 15:33
Plz Help Me With Meassge That Appear In Infinty Box dark20054 Chinese Miracle & PinFinder 2 11-03-2007 22:04
infinty box plz help tarunvishal Infinity-Box 1 07-23-2007 12:22
Page generated in 0.24414 seconds with 11 queries
