Old 08-12-2013, 17:44   #1 (permalink)
Member: 638779
Thanks Meter: 201
Help with iphone 4 clone 1sim
hi
i have this phone i flash it without save backup of flash file
but no flash file with same name work for it
this is info from phone before flash operation
Operation: Read Information
mode-2 META
interface: META_DLL_v6.1108.00
Connect...
Connecting...
done
Release Power button now !
BaseBand chip version: MT6235B, E00
ECO version:
DSP firmware version:  2000.00.00
DSP patch version: 1.0
S/W version: MAUI.08B.W09.12.MP.V13
H/W board version: KINGSTAR35_08B_HW
Melody version Melody V0.0
Version: MAUI.08B.W09.12.MP.V13
detecting structure imei...
 done
81 byte(s) read
imei #1: 35541279004189407810
Shutdown...
done
Finished, time used: 48 sec
Remove/Install battery now !
if i flash it with this one the icons are reverse (upside down) and home button not work digitizer work
KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09 _12_MP_V13__Iphone-4G_2010-10-19_128m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml_Id_Th_ Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M
with all this flashes home work fine screen image and icons good condition but digitizer not work!!!
*KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W0 9_12_XQ_V01_2011-07-15__A1332_128m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml _Id_Th_Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M
*KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W0 9_12_4S_CSZ_V0_0_2012-04-27_128m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml_Id_Th_ Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M
*KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W0 9_12_M22_V13_2012-01-07_128m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml_Id_Th_ Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M
*KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W0 9_12_M22_V14_2012-02-17_128m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml_Id_Th_ Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M
*KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W0 9_12_XQ_V01__firmware_20111229-193713.B4M
please help wich flash file can i use for solve problem
best regards
Old 08-12-2013, 18:19   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,407
Hello,
You should check operation.log file. You can see there what was original phone firmware version - software read version before any flash process.
Old 08-12-2013, 18:54   #3 (permalink)
Member: 638779
Thanks Meter: 201
this is the first operation
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6235:8B00:8A00
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0028]: 0020:00F10000001D [ST] ST01GW3B
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: absent
done
Set baudrate (115200)...
done
interesting cpu type found: 6235:8B00:8A00
ram test (40000000)...
testing 32bit...
32bit ram test passed
testing 16bit...
16bit ram test passed
ram test passed
===>  detect existing firmware structure...
detect ffs...
ffs offset/size: 04000000/04000000
firmware size: 64Mb
ffs size: 64Mb
detect sec ro...
error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND
detect custom parameters...
error:0401:S_CUST_PARA_NOT_SUPPORTED
detect project-id...
project-id: MAUI.08B.W09.12.MP.V13
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
bootloader version: KINGSTAR35_08B_BOOTLOADER_V005_MT6235B_MAUI_08B_W09_12_MP_V13.bi
nfi area detection (3 cores) finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09_12_MP_V13.BIN
project-id: MAUI.08B.W09.12.MP.V13, 00000000
code offset: 00000000
ffs offset/size [01]: 04000000/04000000
rom info structure: [standard] type (07)
TCL-ID is absent
===>  done
startup code area #1 check...
done
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
Old 08-14-2013, 13:49   #4 (permalink)
Member: 130995
Hello,
So, for best results you have to use this firmware:
Old 08-15-2013, 10:26   #5 (permalink)
Member: 638779
Thanks Meter: 201
thank you for your help
but if i flash it with this one the icons are reverse (upside down) and home button not work
other files with same name only have 64mb
i flash it with this one phone not power on i think because this flash is 64mb
KINGSTAR35_08B_PCB01_GPRS_MT6235B_S01.MAUI_08B_W09 _12_MP_V13_2011-01-04_64m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml_Id_Th_V n_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B4M
Page generated in 0.23312 seconds with 7 queries
