03-21-2009, 22:01 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: 202.43.163.90
Member: 323742 Status: Offline Thanks Meter: 73 | Help --> K-Touch A615 Dead by Infinity., Fatal After replaced, there is little problem with the calibration. I format n flash it with several box others. Finally that, I use format whole flash feature of infinity then.. .. All to be destroyed .. Can't be reflash by any box n tool, even with backup file before .. Code: COM21 selected module v2.70 Device: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Action: read NAND firmware read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:0000:0101 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: EC765A3F page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:0076005A003F [04200000] NOR chip is not installed Initialize Done Set baud ... 460800 Set baud Done Identification ... reading structure area... detecting structure... Code: warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed error: can't detect nand chip parameters, default values assigned error: can't detect ffs address Read full flash instead of firmware ! Finished, time used: 23 sec Remove/Install battery now ! Please infinity expert give some instructions, what must be done in this issue.??? Thanxs.!!! |
03-22-2009, 18:09 | #2 (permalink) |
Member: 323742 Status: Offline Thanks Meter: 73 | Weeeeeeeeeeeeeeeks.. .. No one give a help.??? For Moderator, please delete my double thread here --> http://forum.gsmhosting.com/vbb/showthread.php?t=704510 |
03-22-2009, 19:24 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. Why you can not flash phone any more ? What is the problem with flashing ? 2. Did you checked phone battery voltage ? 3. try this software and post results: http://www.infinity-box.com/download...9_for_test.rar p.s. Information for all users: many users make answers to only one question from the questions that was asked by supporter. It is really terrible situation for supporters (we can not understand reason of this kind of ignorance) so from today we will close any thread if users did not make an answers to all questions that was asked by supporters. Thank you for your understanding and cooperation ! |
03-22-2009, 23:12 | #4 (permalink) |
Member: 323742 Status: Offline Thanks Meter: 73 | It say "damage data" .. I tried few firmware from support site, shared from forum n backup from friends. Little lucky, one of them can be writen in, but not success at all. Phone get blank in black when switch'n on for first after flashing. Only once .. then back to dead. I'm sure with power condition, battery and power supply unit. OK, sir.!!! I'll try that test version tomorrow n post result .. Thanxs.!!! .. |
03-24-2009, 19:51 | #5 (permalink) |
Member: 323742 Status: Offline Thanks Meter: 73 | Last result .. Read Firmware Code: COM22 selected module v2.79 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: read NAND firmware read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:0000:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: EC765A3F page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:0076005A003F [04200000] NOR chip is not installed Initialize Done Set baud ... 460800 Set baud Done Identification ... reading bootloader structure area (00010000 bytes)... detecting bootloader structure... warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed warning: can not detect chip parameters, default values assigned error: can't detect ffs address Read full flash instead of firmware ! Finished, time used: 26 sec Remove/Install battery now ! Code: COM22 selected module v2.79 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: read NAND flash read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:0000:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: EC765A3F page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:0076005A003F [04200000] NOR chip is not installed Initialize Done Set baud ... 460800 Set baud Done Identification ... reading bootloader structure area (00010000 bytes)... detecting bootloader structure... warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed warning: can not detect chip parameters, default values assigned reading... warning: number of pages can not be detected warning: probably errors exist during flash read operation Finished, time used: 68 sec Remove/Install battery now ! Code: COM22 selected module v2.79 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: write NAND flash read mode: 01 write: skip: skip: skip: source data: page+spare converting data... done 0x014BA800 bytes identification#1 protocol ver: 04 ver. sw 1: TYM073264_417_PCB04_GPRS_MT6228_S02.073264_417_V1340.BIN ver. sw 2: 073264_417_V1340, EB898A9A ffs offset/size: 01900000/06700000 id-page1 Ok end mark #1 found nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot Off chip: 0031:0000:0101 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: EC765A3F page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: NOR: 0000:000000000000 [00000000] NAND: 00EC:0076005A003F [04200000] NOR chip is not installed Initialize Done Set baud ... 460800 error: unexpected answer: error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 106 sec Remove/Install battery now ! |
philip 390 dead by infinity please help | sajib_ngage | Infinity-Box | 1 | 03-11-2010 22:02 |
help infinity team, v670 dead by infinity !! | wejwej | Infinity-Box | 3 | 07-08-2009 09:38 |
j100i dead by infinity | .::ricky rayya::. | Infinity-Box | 5 | 04-30-2007 17:28 |
