10-12-2017, 22:48 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Belize
Member: 809261 Status: Offline Sonork: 100.61830 Thanks Meter: 100 | help ls775 dead after flash Infinity-Box LG Service Tool [ LGS ] v1.03 Loading firmware ... FType : TOT file BB_Gen : QLM Model : LGLS775 Version : LS775ZV6 SWInfo : user File [0] : PrimaryGPT File [1] : sbl1 File [2] : tz File [3] : hyp File [4] : rpm File [5] : aboot File [6] : sbl1bak File [7] : tzbak File [8] : hypbak File [9] : rpmbak File [10] : abootbak File [11] : persist File [12] : metadata File [13] : laf File [14] : boot File [15] : recovery File [16] : recoverybak File [17] : sec File [18] : factory File [19] : modem File [20] : system Load Ok! Operation : Flash [ v1.03 ] Forced Flash : Disabled Factory Reset : Enabled 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Loading firmware Load ok! Checking compatibility Checking passed! Prepare device Prepare Passed! Secure prepare passed! Start flashing device Flash : PrimaryGPT Flash : sbl1 Flash : tz Flash : hyp Flash : rpm Flash : aboot Flash : sbl1bak Flash : tzbak Flash : hypbak Flash : rpmbak Flash : abootbak Flash : persist Flash : metadata Flash : laf Flash : boot Flash : recovery Flash : recoverybak Flash : sec Flash : factory Flash : modem Flash : system Processing Post-Flashing tune Flash done! Reconnect Power/Cable! Done! Elapsed: 00:05:26 |
10-13-2017, 02:25 | #3 (permalink) |
Member: 809261 Status: Offline Sonork: 100.61830 Thanks Meter: 100 | Said flash was successful but screnn stay black when connect to pc connect in emergency driver mode Cm2 qlm say unsupported if I try reboot or reset function Please does anyone have a solution /advice to fix this phone client coming for it tomorrow? Will be greatly appreciated Thanks in advance! |
10-13-2017, 06:53 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello Why you not check device sw version befote flashing try? Seems as you downgrade device. Post QLM log, probably we can find necessary files for it. |
10-13-2017, 08:59 | #5 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | @JayDi, It will be good if software warm the user about downgrading and stop flashing.. E.g. downgrade detected, Flashing stopped. it will kill the phone. Find same or higher version firmware to flash it. Would be great, if you can manage to do this in next LG module... |
The Following 5 Users Say Thank You to chandanps18 For This Useful Post: |
10-13-2017, 16:44 | #7 (permalink) | |
Member: 809261 Status: Offline Sonork: 100.61830 Thanks Meter: 100 | Quote:
I have may years experience in flashing Samsungs but just flashed a few lgs. 2 night ago successul ls675 flash with lgs module. I am testing the sm and lg modules just Last night if fixed a phone with sm module that I couldn't with Odin becused sm module told me the problem (modem) The phone in question was in a bootloop when I got it the firmware was on zv5 the fimware name was zv6 so I believed it to be and update my bad | |
10-13-2017, 17:05 | #8 (permalink) |
Member: 809261 Status: Offline Sonork: 100.61830 Thanks Meter: 100 | Card found : 147xxxxx , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 20C3D379 ID_BLOCK_I : 007050E1 ID_BLOCK_E : 00310000 ID_BLOCK_L : 0EF6EC6AC5515E49366BE5EA350C84C4 ID_BLOCK_L : 9EF55BF2E76ED055684708C1C3223C1F Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
10-13-2017, 18:43 | #9 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
