Old 03-11-2009, 16:27   #1 (permalink)
bsat's Avatar
Member: 195225
Thanks Meter: 93
help me 6300
help me pls pinout not work of the modele .
7pin.
ic 661u rm217 fcc id ppirm-217.
im tested pinout 1 tx 2.
*#0044# set language englesh
Old 03-11-2009, 16:58   #2 (permalink)
tom313rd's Avatar
Member: 436045
Sonork: 1581208
Thanks Meter: 31
Hello there..
Just open ur fone and see rx tx gnd on PCB solder cable wires it should work jus fine
Br,
TOm
Old 03-11-2009, 19:14   #3 (permalink)
bsat's Avatar
Member: 195225
Thanks Meter: 93
no see rx and tx my friend
Old 03-11-2009, 23:47   #4 (permalink)
Member: 148515
Thanks Meter: 14,904
hello!
start from testing system connector with multimeter:
1. set multimeter to voltage measuring.
2. check bettery voltage, it should be more than 3,7volts
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone battery attached)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
if no such voltages- post PCB picture, maybe someone will recognise it
Old 05-11-2009, 17:10   #5 (permalink)
Salem_Gsm's Avatar
Member: 182574
Thanks Meter: 54
if your mobile connector type is simular as 2x7 but it work with 2x5 connector i have test it and pinout is so :
5-GND
4-TX
9-RX
salem_gsm
Old 05-11-2009, 17:11   #6 (permalink)
Salem_Gsm's Avatar
Member: 182574
Thanks Meter: 54
5-GND
4-TX
9-RX
salem_gsm
Old 05-11-2009, 17:18   #7 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 267
very very urgent reply
see
posted date
03-11-09, 07:27 PM
plz help me 6300 no network illu Nokia Hardware & Hardware Repair 4 05-02-2010 09:18
Help Me, 6300 "CONTACT SERVICE" with battery? gsm_surya Nokia Hardware & Hardware Repair 14 02-22-2010 13:11
HELP ME!!!6300 with SecHash error on flash & erase 22229999 Universalbox 4 02-19-2008 23:20
Page generated in 0.26949 seconds with 8 queries
