08-07-2009, 23:05 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: egypt Age: 37
Member: 419703 Status: Offline Thanks Meter: 123 | help me anycool d66+ verint new ded help me anycool d66+ verint new ded after format erer adress COM15 selected module v2.87 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A203:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. D:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. D:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom structure pass 1... ....................... detect standard fat location pass #1... .................................................. .. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 detecting ffs/eeprom structure pass 2... ....................... detect standard fat location pass #1... .................................................. .. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok element #2 Check firmware integrity Done Check firmware content ... detecting firmware version... .................................................. .............. .................................................. .............. done warning: can not detect firmware version if software not respond/freez: make "Find firmware version (slow process)" unchecked and repeat operation. detecting firmware build... .................................................. .. firmware build: 200804211159 detecting product-id... .................................................. .............. done detecting languages... ........................................... language parameters detected detected languages: En Ru Fr Es It De Vn Tr Farsi Pt Ar Check firmware content Done Backup required data ... Finished, time used: 196 sec Remove/Install battery now ! |
08-07-2009, 23:06 | #2 (permalink) |
Member: 419703 Status: Offline Thanks Meter: 123 | COM15 selected module v2.87 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair "bad software" (mode-2) Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A203:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. D:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. D:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... phase #1... .................................................. .............. phase #2... .................................................. .............. done error: firmware protection firmware structure #8 is not found What to do: 1. Be sure that your phone really has "bad software" problem, in other case do NOT use "bad software" button ! 2. Repeat "bad software" operation several times to avoid communication problems. 3. Flash phone with firmware from support area and repeat "bad software" operation. If still no luck: 1. read full flash and send to support: [email protected] 2. send "operation.log" file to support: [email protected] error: autodetection failed Finished, time used: 164 sec Remove/Install battery now ! |
08-07-2009, 23:07 | #3 (permalink) |
Member: 419703 Status: Offline Thanks Meter: 123 | COM15 selected module v2.87 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair "bad software" (mode-1) Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A203:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. D:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. D:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... phase #1... .................................................. .............. phase #2... .................................................. .............. done error: firmware protection firmware structure #8 is not found What to do: 1. Be sure that your phone really has "bad software" problem, in other case do NOT use "bad software" button ! 2. Repeat "bad software" operation several times to avoid communication problems. 3. Flash phone with firmware from support area and repeat "bad software" operation. If still no luck: 1. read full flash and send to support: [email protected] 2. send "operation.log" file to support: [email protected] error: autodetection failed Finished, time used: 139 sec Remove/Install battery now ! |
08-09-2009, 14:48 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | you must flash phone with good flash file. if future I suggest you never use "format whole flash chip" function if you do not know what this function do. |
08-10-2009, 23:33 | #6 (permalink) |
Member: 419703 Status: Offline Thanks Meter: 123 | thanx you But I'm giving you all the flashes and the phone anycool And also did not work with the mind that he was improperly before the work Format |
08-10-2009, 23:35 | #7 (permalink) |
Member: 419703 Status: Offline Thanks Meter: 123 | Defect lies in the program because of this letter which you have to the death of the phone and change the title of Lacey, which led to the Flash Format Khati I am sure that is not my fault or the phone because I am not a professional and beginning |
08-13-2009, 23:19 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Hello, Please, post here answers for the next questions: 1. what was with phone when you have got it in your hands ? 2. do you have original full flash backup ? 3. what was original phone firmware version ? Please, post here answers for all questions. Thank you very much in advance ! |
08-14-2009, 01:00 | #11 (permalink) |
Member: 419703 Status: Offline Thanks Meter: 123 | Hello The case of the phone was very good and it has the disadvantage of Ristart when Joudecrihp 2 - Format the work you gave me the message above as existing 3 - answered without 4 - and read the full Avlacp 5 - The Format full comblite again answered "Yes" 6 - Phone did not work, Matt 7 - I return the backup 8_ came letters above 9 - by giving you all the flash anycool 10 - did not work also 11 - and worked only for the flash anycool t808 12 - The phone model originally d66 + Greetings to you |
pls help me nktel a200 after flash ded | tanveer ahmad | Infinity-Box | 4 | 03-28-2010 11:48 |
help me anycool t818 | ultimo9999 | Chinese Models & Cloned Phones | 12 | 09-16-2008 07:30 |
help me anycool t818 | ultimo9999 | Chinese Models & Cloned Phones | 0 | 08-24-2008 19:49 |
pls help me anycool t618 | simurgxxx | Infinity-Box | 4 | 07-09-2008 12:00 |
Please help ( Anycool d66 ) | hussamaster | Infinity-Box | 3 | 12-30-2007 03:21 |
