05-04-2007, 00:46 | #1 (permalink) |
Junior Member Join Date: Oct 2004 Age: 45
Member: 84991 Status: Offline Thanks Meter: 0 | Help me benq-siemens AP75 How read all benq- siemens all full flash ? |
05-05-2007, 01:31 | #7 (permalink) |
Member: 84991 Status: Offline Thanks Meter: 0 | Device: BenQ M315, Siemens AP75 Checking data, wait... Action: Read flash Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... 203125 Set Baud Done Check Flash... Check Flash Done Check Parameters... part 1 of 1... Reading... file saved: backup_full_part_1_of_1_20070504-081007.4BX.bin Flash: 0089:885500010001 Finished, time used: 485 sec Remove/Install battery now ! Loading file v.02... data error Loading failed, probably damaged data file. I find out the BXs ackup_full_part_1_of_1_20070504-081007.4s in the BModule127.Did not find out the LanguagePack and of Flexes I LoanFirmware backup_full_part_1_of_1_20070504-081007.4BX loading failed, probably damaged bata file data error ?? |
05-05-2007, 10:20 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you need to send readed backups to [email protected] for processing. later we will upload them on server in original way they can not be flashed back to phone |
Help for benq-siemens el71 unlocking ! | kimo59 | SIEM Service Tools | 35 | 01-21-2010 19:41 |
sucess unlock Benq siemens AP75 | rotelcam | Infinity-Box | 3 | 07-18-2009 08:31 |
how to unlock Benq siemens AP75 | dompezvicky | Infinity-Box | 1 | 03-23-2007 09:25 |
Update N°10 - V1.21.7.2006 - Furious-Gold BENQ-SIEMENS AP75 ADDED !!! | .:hack3r2k:. | FuriousGold | 26 | 11-08-2006 17:58 |
benq siemens AP75 | zolla | FuriouS II | 4 | 08-11-2006 15:05 |
