10-21-2018, 12:19 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Bohicon (Rep of Benin)
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | infinity box: unknown device when connect to pc |
10-21-2018, 15:50 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Try to insert smart card into other box/dongle/card reader and check result. Br. Infinity Box Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-22-2018, 09:09 | #3 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Try to insert Smart-Card into another Card-Reader or Box (if you have it) If problem still exist: - Remove Smart-Card from Card-Reader - Clean Smart-Card contacts - Try to use hot air gun and heat Smart-Card - Insert Smart-Card back to Card-reader | |
10-23-2018, 15:35 | #4 (permalink) |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | first of all I thank you for the assistance and promptitude of the answers here is everything I tried: - I changed pc and nothing has changed - I put it in a best dongle and now, it shows: === DongleManager [Infinity] v1.72 [23/10/2018 16:29:12] === Searching... Dongle can't be found: Card with specified AID is not found - I went yesterday bought another CM2, and strangely it continues to display: === DongleManager [Infinity] v1.72 [23/10/2018 16:29:12] === Searching... Dongle can't be found: Card with specified AID is not found I change the pc for the new dongle and it has the same thing. I went to your site to download the latest version of dongle manger ( the 1.72 and shell) and i reinstall the driver and i always === DongleManager [Infinity] v1.72 [23/10/2018 16:29:12] === Searching... Dongle can't be found: Card with specified AID is not found I am really confused and need help. |
10-23-2018, 18:36 | #6 (permalink) |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | I think the same thing too, but i have the follow driver . - CardReader_AlcorMicro - CardReader_AlcorMicro.AU9540_1.7.26.0_WHQL - CardReader_e-gate - CardReader_Omnikey_CCID - CardReader_PKey - CardReader_SCM_SCR3310 which is the good smart card driver. thk |
10-23-2018, 19:39 | #7 (permalink) | |
Do you know, what is your dongle S/N ? | |
10-24-2018, 09:08 | #8 (permalink) |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | ok, how can I read SN if the dongle refuses to install. what's strange is that I installed it, even for my friends. Can someone send me an installation procedure? thank you |
10-24-2018, 10:03 | #9 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
How did you activated without knowing its S/n ? Keep wasting your time but dont waste supporters time. | |
The Following User Says Thank You to Kirumira For This Useful Post: |
10-24-2018, 14:25 | #10 (permalink) |
Member: 862014 Status: Offline Sonork: 100.1608307 Thanks Meter: 64 | i was using before and one morning it refuse to work. when i remove the key the infinity box connect correctly but when i put the smarth cart it display "devise" not found. |
10-24-2018, 15:54 | #12 (permalink) | |
Instruction for "unknown device": Try to connect Dongle to another PC Try to insert Smart-Card into another Card-Reader or Box (if you have it) If problem still exist: - Remove Smart-Card from Card-Reader - Clean Smart-Card contacts - Try to use hot air gun and heat Smart-Card - Insert Smart-Card back to Card-reader If problem still exist this means it's a hardware problem and you need new Smart-Card. | |
10-24-2018, 20:34 | #13 (permalink) | |
Do you have another PC to try ? drivers depends on your card-reader type but in most cases windows install drivers automatically. so first step - try with other PC. result ? | |
