08-26-2009, 23:23 | #1 (permalink) |
No Life Poster Join Date: Sep 2003 Location: latin america Age: 48
Member: 38642 Status: Offline Thanks Meter: 69 | help me...with dual sim.. i have mark DOTCOM(mb-2000tv) dual sim.. but locked messege and PB lock... code security is 1234... but not unlock with this code... i try ffs format show me error test mode.. help me please.. bye br santiago lee |
08-26-2009, 23:25 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
do full backup (eeprom and flash) then format phone completly... and add here ur fw details.. | |
08-27-2009, 00:06 | #3 (permalink) | |
Member: 38642 Status: Offline Thanks Meter: 69 | Quote:
but show me this error.. "Do you have full flash backup ? Loading file v.02... TL_T819Z_P14U00F07L31_01_12__fullflash_20090826-103053.B0M.bin loaded detected record size adjusted detected record size adjusted detected record size adjusted Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:CE03:0005 status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 77 sec Remove/Install battery now ! can u help me..?? bye br santiago lee | |
08-27-2009, 00:10 | #4 (permalink) | |
only calibrate the touchscreen by pressing "Calibrate Touchscrren" button on the software... | |
08-27-2009, 14:13 | #5 (permalink) | |
but itīs my logs when "calibrate touchscreen" COM150 [VCP0] selected module v2.89 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... TL_T819Z_P14U00F07L31_01_12__fullflash_20090826-103053.B0M.bin loaded detected record size adjusted detected record size adjusted detected record size adjusted Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:CE03:0005 status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 80 sec Remove/Install battery now ! show me error all time.. how can solve this..?? bye br santiago lee | |
08-27-2009, 14:36 | #6 (permalink) | |
check the support for flash file..exist on support.. | |
08-27-2009, 20:39 | #7 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
what cable do you use as interface? | |
08-29-2009, 20:32 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you must modify your main infinity box. one diode which is limiting current must be shortcutted. please check infinity pinfinder user manual, trubleshooting section. there is pictures how it is look like and how to shortcut it. after you remove diode pifnidner output voltage will increase and there will be no more test mode problems |
HELP! I have a phone from China with dual Sims and the Nextel one won't co-operate | robzombie450 | Phone Unlocking Codes & Maps | 1 | 11-21-2009 00:35 |
NN95 Mini Dual Slide Phone With Dual SIM Card & Bluetooth - Pink | IPMART | ipmart WebShop | 0 | 07-29-2009 06:34 |
V339 Dual Slide TV Phone with Dual SIM Card & Bluetooth (silver back housing) | IPMART | ipmart WebShop | 0 | 03-26-2009 05:00 |
Help Me With MTK 6226 Dual Sim (N96i) White LCD | minihack | SpiderMan | 3 | 04-28-2008 20:27 |
Hi Can some Help me with the sim clock Number | Ari | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-20-2001 10:23 |
