Old 05-17-2008, 19:49   #1 (permalink)
Member: 239168
Thanks Meter: 104
Help Me For Eeprom File For N95 (tx,rx On Board)
hi,
i need good eeprom file for the n95( attached below type set)
Old 05-17-2008, 21:09   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
in order to help you we need to know your phone original software version
Old 05-18-2008, 03:30   #3 (permalink)
elkawasmy's Avatar
Member: 113200
Sonork: 100.1573773
Thanks Meter: 87
make full detailed info with Infinty then post it here so we can help u
there is more than 50 eeprom file for N95 with diffrant named and hardware
BR,
Elkawasmy
Old 05-18-2008, 05:53   #4 (permalink)
Member: 239168
Thanks Meter: 104
the detailed info and format ffs details as below
COM6 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:1136:83A6
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.AE8ACC1A.[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1217A .BIN_103A0BEB].rpl
identification#1 detection finished
device-id: AE8ACC1A
identification#1 protocol ver: 04
ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1217A .BIN
ver. sw2: B10_EFATRIS_V1217A, 14F4C5EF
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _AE8ACC1A_T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFAT RIS_V1217A.BIN_103A0BEB_20080517-134715.B0X.bin
Finished, time used: 171 sec
Remove/Install battery now !
format ffs
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6226
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: B10_EFATRIS_V1217A
Version:
detecting structure #2...
done
60 byte(s) read
imei: 35783501064644
connection Ok
building list...
done
items to clear: 184
warning: wrong packet cs
182 of 184 items cleared
building list...
done
0 items remains
Finished, time used: 56 sec
Old 05-18-2008, 11:48   #5 (permalink)
Member: 148515
hello!
flashfiles/ChineseMiracle/_MT6226/repair_eeprom/T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1217A _16m_En_Ru_Fr_Es_Id_Th_Ar.B0M.bin
Help Me In Erase Files For Nokia 3650 zonetrichur Nokia Hardware & Hardware Repair 2 11-26-2007 09:52
Who help me witch ask file for E50 Nestor7 Nokia Base Band 5 ( BB-5 ) 1 12-08-2006 19:08
pls help me to get files for infinity stivubicco Infinity-Box 2 11-26-2005 19:17
Help! I need eeprom file for Sagem MC916 Koval Infineon C16X M51 & ARM7 M52 BASED 6 04-09-2003 08:19
Plaese, help me with map-file for S40, I have 1345678... Imei zoic Phone Unlocking Codes & Maps 2 10-15-2002 18:59
Page generated in 0.18385 seconds with 10 queries
