02-02-2008, 12:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks Meter: 104 | help me to flash AMYCOOL D66+ but today got one amycool D66+.customer said he gave it to another service centre for restart problem-after their service set dead.i did format ffs two times-no scope-set still in dead. so i think it need flashing-am i right?but i dont know which file and procedure. in support section saw files for ""ANYCOOL D66+""(I MEAN NOT AMYCOOL) ONLY SO WHAT I DO? |
02-03-2008, 06:25 | #3 (permalink) |
Member: 239168 Status: Offline Thanks Meter: 104 | eeprom and flash file backup as below backup_eeprom[E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN]_20080201-022022.B0E backup_system_log_3BE3104A_E553_K4SMCHARAB_E553_GP RS_MT6226_S01.01_1.BIN_A36E3A79_20 080201-024236.B0X |
02-03-2008, 08:21 | #5 (permalink) | |
Member: 239168 Status: Offline Thanks Meter: 104 | Quote: i tried to flash using ur filr backup_flash_E553_K4SMCHARAB_E553_GPRS_MT6226_S01[1].01_1.BIN__20071118-175820.B0M but when load above file in software window an information window came. '''''U HAVE LOADED FILE WITH SECURITY FEAUTURES ENABLED-NEED ASK/RPL AFTER FLASH TO SET ON"""" so i did not forward any other way to set on without rpl? thank u | |
02-03-2008, 14:22 | #6 (permalink) |
Member: 239168 Status: Offline Thanks Meter: 104 | DETAILED INFO AS BELOW COM2 [Serial0] selected Device: Autodetect Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... slowest Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced[/B]] (or higher) generation identification data Ok identification data backup saved: id.3BE3104A.[E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN_A36E 3A79].rpl identification detection finished device-id: 3BE3104A protocol ver: 04 ver. sw1: E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_K4SMCHARAB.01.1 ffs offset/size: 00800000/001FF000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address[00E00000] ? standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF detection phase #3... .................................................. .............. done detecting structure pass 1... ................... detect standard location pass #1... .................................................. ...... detect extended location pass #1... .................................................. ...... location can't be detected eeprom element #1 detection failed error: autodetection failed file saved: backup_system_log_3BE3104A_E553_K4SMCHARAB_E553_GP RS_MT6226_S01.01_1.BIN_A36E3A79_20080203-050455.B0X.bin Finished, time used: 115 sec Remove/Install battery now ! """"""""""""""""""""""""ENHANCED"""""""""SO IT NEED RPL? AM I RIGHT? |
02-03-2008, 14:22 | #7 (permalink) |
02-04-2008, 22:50 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i affraid that those persons from another service center flashed phone with wrong file. best way now is to find same working phone and read out full backup. use this backup to restore your faulty phone |
07-10-2008, 17:49 | #10 (permalink) |
Freak Poster Join Date: Mar 2006 Location: EVRY WHERE
Member: 240107 Status: Offline Thanks Meter: 21 | COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:CCBA:423B high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.424C1457.[E553_K10SMCHARAB_E553_GPRS_MT6226_S01.00_0.BIN_C0E 9FF6C].rpl identification#1 detection finished device-id: 424C1457 identification#1 protocol ver: 04 ver. sw1: E553_K10SMCHARAB_E553_GPRS_MT6226_S01.00_0.BIN ver. sw2: E553_K10SMCHARAB.00.0, 9300163F ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E10000 Detected eeprom/ffs address is non-standard: 00E10000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E10000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 001F0000 ffs chip: 00 eeprom/ffs area: 00000000:00E10000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E553_K10SMCHARAB_E553_GPRS_MT6226_S01.00_0.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[E553_K10SMCHARAB_E553_GPRS_MT6226_S01.00_0.BIN]_20080710-192829.B0E.bin flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_424C14 57_E553_K10SMCHARAB_E553_GPRS_MT6226_S01.00_0.BIN_ C0E9FF6C_20080710-192841.B0X.bin Area: Firmware flash: EC257E25082501:29EA0000000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_424C14 57_E553_K10SMCHARAB_E553_GPRS_MT6226_S01.00_0.BIN_ C0E9FF6C_20080710-193518.B0X.bin Finished, time used: 606 sec Remove/Install battery now ! ----------------------------------------------------------------------- its ok but the lcd was rooling down |
07-10-2008, 23:16 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! what file did you use for flashing? flashfiles/ChineseMiracle/_MT6226/E553_K10SMCHARAB_E553_GPRS_MT6226_S01.00_0__Anycoo l-D66+_16m_En_Ru_Cn_Ar.B0M.bin |
07-11-2008, 21:14 | #12 (permalink) |
Member: 240107 Status: Offline Thanks Meter: 21 | hello evry body i try to flash the fone with this flash file but (E553_K10SMCHARAB_E553_GPRS_MT6226_S01.00_0.BIN]_20080710-192829.B0E.bin)but it give me white screen i try another flash file but still white screen or bad lcd(up for down) |
07-12-2008, 11:18 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | helo mr. ELBORSAIEDY! this means that version E553_K10SMCHARAB_E553_GPRS_MT6226_S01.00_0 is NOT youoriginal version. please open operation.log file and search for first operation which you did with this phone. there you will see original software version. post it here |
07-17-2008, 16:10 | #14 (permalink) |
Member: 240107 Status: Offline Thanks Meter: 21 | HELLO ( INFINTY TEEM) ITRIED TO OPEN THAT LOG FILE BUT I FIND THAT(system_log_2650DCEF_E553_XZY1ARTHRUTR_E553_GP RS_MT6226_S01.01_1.BIN_7CB64CB5_20080710-163509.B0X.bin) AND SEARCH FOR THAT V AT LAST I FOUND IT - REFLASH THE FONE BUT STILL THE LCD NOT CORRECT WHAT IS THE WRONG?? PLZ HELP ME |
07-17-2008, 16:29 | #15 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Egypt Age: 46
Member: 99784 Status: Offline Thanks Meter: 865 | try this flash file MTK_ROMINFO_v04 E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN I see one amycool with this flash file try to find in support and flash it |
help me foll flash anycool d66+ | GSM_BB5 | Infinity-Box | 2 | 08-10-2009 23:38 |
Help me to flash P310-Operation failed due to an error | sources | UST Pro II | 3 | 09-18-2008 12:21 |
Help me to flash my 6280. I have tried twice now and am ready to try again! | stickybudd | Nokia Base Band 5 ( BB-5 ) | 2 | 08-03-2006 23:18 |
help me to flash 6600 | mnmfaizal | UFS2 + UFS3-Tornadoflasher | 1 | 07-30-2005 00:56 |
Help me to flash PPM for 8310 | VinhHai | Nokia Multimedia | 3 | 11-01-2003 09:43 |
