Old 01-31-2008, 13:21   #1 (permalink)
MARK26's Avatar
Member: 626582
Thanks Meter: 15
help me how to revive n95 china
Good evening to everybody. I would like to ask for a suggestion on how to revive n95 china single sim phone. Here is the screenshot.
Old 02-01-2008, 01:31   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
cannot see your picture, can you explane in words what is wrong with phone?
Old 02-01-2008, 02:35   #3 (permalink)
MARK26's Avatar
Member: 626582
Thanks Meter: 15
I'm sorry sie for the failed screenshot. Anyway, here is the logs:
COM19 [VCP0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200
Initializing[6226:8A02:8A01]...
chip: 0031:7456:E456
Connecting, wait...
error: can't finalize test mide
repeat operation and HOLD phone "Power" button long time !
Operation failed !
Finished, time used: 25 sec
Remove/Install battery now !
Any idea on this one sir?
Old 02-01-2008, 02:53   #4 (permalink)
Member: 148515
hello!
what problem with phone?
Can you read full backup?
Old 02-01-2008, 03:12   #5 (permalink)
MARK26's Avatar
Member: 626582
Thanks Meter: 15
It was a dead unit when the customer handed me the cellphone. Yes, I already did the READ full backup thing. In other forums, they suggest me to flash it. But I am confused... there are a couple of N95 flashfiles in the support area. I don't know what flash files to use.
Old 02-01-2008, 03:51   #6 (permalink)
Member: 148515
hello!
please post here a reading backup log
i will advice what file to use
Old 02-01-2008, 06:00   #7 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
its very important to post your back up logs here so that we can help you bro....
Old 02-02-2008, 04:56   #8 (permalink)
MARK26's Avatar
Member: 626582
Thanks Meter: 15
Sir, I tried to click the Read Full Flash tab and here is the logs. But there's a question popped on the screen which I am not really sure what to answer so I click NO.
Please help. Thank you so much!
Device: Autodetect 6205-6227 NOR
advanced flash detection active
Action: read NOR flash
Boot...
baud autodetection active
19200
Connecting, wait...
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 Ok
security area backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.85899A1C.[N618_PCB01_GPRS_MT6227_S01.1.BIN_BD6C27EF].rpl
identification#1 detection finished
device-id: 85899A1C
identification#1 protocol ver: 04
ver. sw1: N618_PCB01_GPRS_MT6227_S01.1.BIN
ver. sw2: N618.1
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00FC0000
Detected eeprom/ffs address is non-standard: 00FC0000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
Do you want to use standard eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
operation terminated by user
error: critical error#1 during ffs size detection
error: can't detect eeprom/ffs address/size
reading [flash[N618_PCB01_GPRS_MT6227_S01.1.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_flash[N618_PCB01_GPRS_MT6227_S01.1.BIN]_20080202-113041.B0M.bin
file saved: backup_system_log_85899A1C_N618_PCB01_GPRS_MT6227_ S01.1.BIN_BD6C27EF_20080202-113049.B0X.bin
Finished, time used: 189 sec
how to formate n95 china jeddha Chinese Models & Cloned Phones 4 10-18-2008 18:46
need help u880 how to revive runner30 VygisToolbox 2 05-03-2008 12:42
Help Me-how Convert Jaf N95 Cable To Use In Mtbox. zonetrichur UID - Box 1 09-13-2007 06:27
Help me how to transfer SMS from old nokia to new O2 coolnitin_316 WD2 & APE (Symbian Phones) 0 11-17-2006 19:01
please help me how to install games to motorola v303 exelgrade Motorola P2k 0 01-27-2006 14:10
Page generated in 0.16883 seconds with 9 queries
