09-22-2007, 16:07 | #1 (permalink) |
Banned Join Date: Apr 2007
Member: 480351 Status: Offline Thanks Meter: 5 | help me how to unlock N73 ? i want to ask, is my phone LOCKED or hardware problem ?, if yes how to solve my problem ?? which cable i must use ? thanks |
09-22-2007, 18:24 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Cable: Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 "ChineseMiracle": how to repair "reboot with SIM card" 1. make full flash backup for emergency case (use 921000 speed for fast operation) 2. select "safe format method" 3. make "format ffs" 4. remove/install battery 5. press and hold phone "Power" button during 30-40 sec to make phone powered-on if phone Ok go to step-6 if phone not Ok, go to step 2 and select "complete format method" 6. restore original imei |
09-26-2007, 06:21 | #8 (permalink) |
Member: 480351 Status: Offline Thanks Meter: 5 | its not hardware probel... every i insert the sim card phone only show nokia and enter pin... ok i have enter pin and then phone not power on... if i not put the simcard...phone normal |
v3re unlock field pleas help me how to unlock | lilong_lee | Smart-Clip | 8 | 02-05-2010 14:03 |
To Sir Siroya & Vsh-gsm Help Me How To Unlock Z510 | fixed | UST Pro II | 0 | 06-09-2008 03:44 |
S16 !!! Please help me!!! How to unlock SP-lock??? | KisaKot | x1x to x45/x50 | 2 | 11-13-2002 10:35 |
Help me-how to unlock my 6210 ver. 5.02? | SAJ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 08-08-2001 22:14 |
Help me-how to unlock my 6210 ver. 5.02? | SAJ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-13-2001 21:26 |
