12-25-2008, 07:40 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: IN mobile's
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | help me infinity module v2.72 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:8903:0006 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... slowest Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: EC257E25062501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: TOP23_07A_PCB01_GPRS_MT6223_S00.N1112_V5_53.BIN ver. sw 2: N1112_V5.53, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00700000 flash: EC257E25062501:2AEA0000000000 checking area [00000000]: 00000000-007FFFFF... eeprom/ffs found near: 007F0000 Detected eeprom/ffs address is non-standard: 007F0000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00700000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25062501:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25062501:2AEA0000000000 Finalization Done Finished, time used: 36 sec Remove/Install battery now ! help me infinity plzz as soon possible |
12-25-2008, 07:44 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | if u send here full details about our problem then possible that most of member gave u good ans of u r problem as soon as possible ..... |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
12-25-2008, 08:00 | #3 (permalink) | |
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | sorry fo incomplete Quote:
dear team phone still dead N there is no hardware problem plz give the write way | |
Help me infinity team step by step flash lg kg195 with infinity | aamirgsm | Infinity-Box | 1 | 08-07-2008 14:28 |
help me infinity team | nabildeco@yahoo | Infinity-Box | 1 | 03-07-2007 12:09 |
help me infinity for myC261 | chamin | Motorola ODM | 1 | 01-20-2007 01:12 |
PLZ HELP ME infinity-box error | amine gsm maroc | Infinity-Box | 2 | 09-07-2006 20:20 |
i have probel with flash c118 please help me infinity team | gsm4libya | Infinity-Box | 2 | 05-11-2006 12:03 |
