03-28-2010, 09:18 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: where love is Age: 33
Member: 1002000 Status: Offline Sonork: 100.1604575 Thanks Meter: 90 | HERE IS LOG COM6 [VCP0] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 355995013590783 current otp imei: 000000000000000 file saved: C:\Program Files\InfinityBox\LGA\eeprom_355995013590783_LG-KG110_20100328-134815.B1E.bin ........ version: XXX-XXV10j91KG110P40 Check flash Done Check space ... current eeprom imei: 355995013590783 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 40 sec Remove/Install battery now ! |
03-28-2010, 09:26 | #4 (permalink) | |
Freak Poster Join Date: Jan 2009 Location: chennai
Member: 958595 Status: Offline Thanks Meter: 18 | Quote:
03-28-2010, 09:28 | #7 (permalink) | |
03-28-2010, 09:30 | #9 (permalink) |
Member: 958595 Status: Offline Thanks Meter: 18 | my old log COM5 [VCP4] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 355995012237295 current otp imei: 050004000210281 file saved: C:\Program Files\InfinityBox\LGA\eeprom_355995012237295_LG-KG110_20100319-180625.B1E.bin ........ version: 602-03V10b20KG110P40 Check flash Done Check space ... current eeprom imei: 355995012237295 ................................ finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 47 sec Remove/Install battery now ! |
03-28-2010, 09:41 | #12 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 199340 Status: Offline Sonork: 100.1592925 Thanks Meter: 192 | if kg110 imei 000000 perfect solution. dear all 1. Download files from support area folder: \flashfiles\LG\KG110\full_flash\KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453.B1M 2. Read instruction How_to_write_full_flash.txt 1. Go to software "Flash" page: "Firmware (code)": checked "File system": un-checked "Alchemy data": un-checked "Eeprom": un-checked 2. Load full flash file via "Load Firmware (code)" button "Format FFS": un-checked "Smart write": checked "Keep calibration area": un-checked 3. Flash phone (press flash "Write" button) and nothing yaar.check imei enjoy |
03-28-2010, 09:41 | #13 (permalink) |
Member: 958595 Status: Offline Thanks Meter: 18 | |
03-28-2010, 09:58 | #15 (permalink) | |
Member: 1002000 Status: Offline Sonork: 100.1604575 Thanks Meter: 90 | Quote:
samaj mein nahi ata hai mujhr kya tum yahoope aasakte ho meri id [email protected] | |
X820 need to change IMEI. phone have imei 0000000 | PSG | Trident/AGERE Platform | 3 | 11-08-2007 19:07 |
[e730] imei 0000000 | moms | SWIFT Platform | 1 | 11-23-2006 22:53 |
j70 imei 0000000... | Destructor | Sony | 9 | 09-08-2005 10:38 |
NEC 338 imei 0000000 destroyed with server | OBILIXx | NEC | 4 | 03-24-2005 02:03 |
nokia 2100 imei 0000000.... contact servise | Unlocker AL | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 06-09-2004 21:19 |
