Help me jaydi sir SPD 7715 NAND FORMAT ERROR Operation : Format File System / Reset Settings [ v1.16 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 34 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Unknown structure detected! Something went wrong :( If phone work normally - check correct selection (Model,FlashType)! Elapsed: 00:00:28 Reconnect Power/Cable! |
Select nand boot 1st or If have select similar model any pac file & Boot : cpu SC77xx |
ok bro i try .................... |
It can be NOT nand. Try with eMMC also. |
