08-04-2009, 18:59 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: sri lanka Age: 44
Member: 700923 Status: Offline Thanks Meter: 13 | help me N99 tv phone after format not on module v2.85 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #08 in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #09 in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #0A in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #0B in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #0C in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #0D in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #0E in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #0F in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 10/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:C3798100000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: C371817989180907090F81710948E1710068903040780028 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00380000 flash: 01227E221A2201:C3798100000000 checking area [00000000]: 00000000-003FFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00380000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00080000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00380000-003FFFFF detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20090804-231102.B0E.bin flash: 01227E221A2201:C3798100000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E221A2201:C3798100000000 Finalization Done Finished, time used: 137 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
08-04-2009, 19:06 | #2 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | write eprom backup again if u made before format.if not than "read detailed information" find flash file firmware and find same file in infinity box support area&flash phone. Good luck |
N95-8G china phone after format dead help! | alvinteh | SpiderMan | 5 | 01-29-2010 03:01 |
help me 5310 flash mx-key but not on | w850 | Nokia Base Band 5 ( BB-5 ) | 1 | 12-27-2009 17:29 |
help me N99 tv phone after flash not on | w850 | Infinity-Box | 2 | 07-31-2009 17:38 |
Please Help me N99......... | karikari | Infinity-Box | 1 | 10-11-2008 21:06 |
Help me ZT6618 tv not supported | Kent İletişim | Infinity-Box | 5 | 02-19-2008 20:45 |
