10-10-2008, 21:21 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: ghana
Member: 193967 Status: Offline Thanks Meter: 26 | infinity ok but problem wirh pinfinder can some one please help me solve this problem for i am worried |
10-10-2008, 21:30 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
i think you will get your ans. | |
10-10-2008, 21:32 | #3 (permalink) |
Member: 193967 Status: Offline Thanks Meter: 26 | fake pinfinder may i know fello brothers if there are fake pinfinder on the market i am asking this because i just bought my infinity box and the pinfinder the infinity box is ok but cannot detect the pinfinder if connected to the box i collected one from a frend and it connected fine but my own does not connect what might be the problem with it can you good one ple help me out |
10-10-2008, 21:37 | #4 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Can you chek your infinity com port? Can you set same com port on pinfinder? Can you update your dongle? If all it's ok then your finder prob contact your reseller. |
10-10-2008, 21:38 | #5 (permalink) | |
No Life Poster Join Date: Jan 2005 Age: 48
Member: 105817 Status: Offline Thanks Meter: 133 | Quote:
10-10-2008, 21:41 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @kingsley baafoe Try to change short RJ45-RJ45 box to PinFinder cable . Do you see PinFinder power led activity when you connect PinFinder to your box ? |
10-10-2008, 21:43 | #7 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 732994 Status: Offline Thanks Meter: 81 | use dongle manager to update Select Pinfinder Update box Open Pinfinder sw Select com port where pinfinder is connected Click Detect select cable Detect Pin Power on when needed Somethings maybe not correct but this is all i remember :P |
10-11-2008, 13:27 | #8 (permalink) | |
Member: 193967 Status: Offline Thanks Meter: 26 | Quote:
one of the ic was not well fixed that have been done and now when i upgrade it can detect pinfinder but the new problem is when i open the software for the pin finder it says "dongle Locating server... Server#1 address found. Connecting to server#1... Server connection successfully established. S/N: xxxxxx, Firmware: 0111.02 Authenticating on server... Authentication successfull. Checking DongleManager version... Your DongleManager is up-to-date. Checking Dongle Identification... Dongle Identification checked. Activating module... Module-04 S/N: 000000000000000000000000000000 Module check error: Server reported error:[0044] Module S/N is already registered. Contact to [email protected] | |
10-11-2008, 14:13 | #9 (permalink) | |
Locating server... Server#1 address found. Connecting to server#1... Server connection successfully established. S/N: xxxxxx, Firmware: 0111.02 Authenticating on server... Authentication successfull. Checking DongleManager version... Your DongleManager is up-to-date. Checking Dongle Identification... Dongle Identification checked. Activating module... Module-04 S/N: 000000000000000000000000000000 Module check error: Server reported error:[0044] Module S/N is already registered. | |
10-11-2008, 18:11 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @kingsley baafoe I suggest you to contact to [email protected] and make very detailed explanation of problem. What was the problem. What you have tried to do. What is the results. VERY detiailed ! |
w200i unlock ok but problem | geepee777 | DreamBox | 8 | 10-16-2008 13:52 |
Chinsees Skyworks CPU ok But problem with Flash IC | .::BHATTI::. | Infinity-Box | 1 | 07-09-2008 08:36 |
KG195 Flash With Infinity ok but? | Kanwalgee | Infinity-Box | 4 | 05-25-2008 14:13 |
i have problem mybe any wan can solved it if i open any soft for infinity ok but if i | gsm4libya | Infinity-Box | 2 | 05-01-2006 11:56 |
