09-14-2007, 10:29 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Message of William Branham
Member: 239523 Status: Offline Thanks Meter: 210 | help me revive a chinese phone I just make complete format (as the phone is restarting with simcard) with chinese miracle module and phone refuse to power on now. software warns me many times that eeprom si not supported and I forced and now phone is dead. it is a chinese phone ZT588. I will like to ask if it will work if I find the same kind to copy its firmware to revive my own. thanks |
09-14-2007, 12:33 | #3 (permalink) |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | hi please try to raed Infinity-Box_ChineseMiracle_How_to_repair_reboot_with_sim.t xt exist in support erea: "ChineseMiracle": how to repair "reboot with SIM card" 1. make full flash backup for emergency case (use 921000 speed for fast operation) 2. select "safe format method" 3. make "format ffs" 4. remove/install battery 5. press and hold phone "Power" button during 30-40 sec to make phone powered-on if phone Ok go to step-6 if phone not Ok, go to step 2 and select "complete format method" 6. restore original imei ----------------------------- & try to read Infinity-Box_How_to_repair_dead_Chinese_phone_MT6226_MT6227 _etc_En.htm in documentation file ( X:\Program Files\InfinityBox\Documentation ) Repair procedure: Start “ChineseMiracle” software. Press "Detailed information" button in "Service" page. Software read from phone some important info. If you will see in Log window text like: “2nd [standard] (or higher) generation model detected” this means that it’s no need to “Repair” your phone via ASK/RPL file but you must simply try to flash phone with different firmware files and finally phone will be alive. No need to read next steps in this manual. you will see in Log window text like: “2nd [enhanced] (or higher) generation model detected” this means that probably phone damaged (can’t power-on due to software fault) and can be repaired via “Repair” procedure. Need to read next steps in this manual. If phone damaged due to software fault, software detect this automatically and offer you to write RPL file in phone (to repair it). If you already have RPL file: press "Yes" and wait several seconds. Phone repaired. No need to read next steps in this manual. If you don’t have RPL file yet: press "No" and follow next steps. Software offer you to create ASK file. Press "Yes". Use Infinity-Box “Client” and generate RPL file from your ASKL file. Copy received RPL file in folder with “ChineseMiracle” software and make "Detailed information" again (to write received RPL file in your phone). |
09-14-2007, 14:27 | #4 (permalink) |
Member: 239523 Status: Offline Thanks Meter: 210 | hi thanks for answer. the problem is that I did not make backup before trying to make format. is there any hopr for me to get its firmwrae and revive it? |
09-15-2007, 00:57 | #7 (permalink) | |
Freak Poster Join Date: Mar 2005 Age: 48
Member: 125482 Status: Offline Thanks Meter: 30 | plzzzzzzzz help me Quote:
i flash phone with flash file in support erae now phone must make ask file t make rpl phone is dead and refuse to make ask file . warning: probably identification data damaged, power-on problem possible error: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.7627CA0E._E553_Y8ARTF_E553_GPRS_MT6226_S01.01_1 .BIN_101267BD_.rplwarning: unknown identification structure: E553_Y8ARTF_E553_GPRS_MT6226_S01.01_1.BIN_101267BD error: ASK file can't be created, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: i have rpl but diffrant about that need id.7627CA0E._E553_Y8ARTF_E553_GPRS_MT6226_S01.01_1 .BIN_101267BD_.rpl my rpl i found it id.7627CA0E.[E553_Y1THAIRUARFRBT_E553_GPRS_MT6226_S01.01_1.BIN_ AF612181].rpl now i think i want flash file from good phone but i cant find any phone the same model..... plzzzzzzzz help me with good flash file or new update can help us to make ask file because phone need rpl. thanks infinity teem. Last edited by hossam_on_line; 09-15-2007 at 01:06. | |
09-16-2007, 01:04 | #9 (permalink) | |
Member: 125482 Status: Offline Thanks Meter: 30 | Quote:
this is the flash file i found it . CM_adv_Nokia-N93i-2sim_E553_Y1THAIRUARFRBT_E553_GPRS_MT6226_S01[1].01_1_16m_En_Fr_Ru_Ar_Th.B0M now phone revive ....i m very habby but still power off with sim card not restarting .... i make safely format ffs and still power when logo start up . i try to make ask file ... COM6 [VCP0] selected Device: Autodetect 6205-6227,6228 nor Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.7627CA0E.[E553_Y1THAIRUARFRBT_E553_GPRS_MT6226_S01.01_1.BIN_ AF612181].rpl identification detection finished device-id: 7627CA0E protocol ver: 04 ver. sw1: E553_Y1THAIRUARFRBT_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_Y1THAIRUARFRBT.01.1 ffs offset/size: 00800000/001FF000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 008B0000 Detected eeprom address is non-standard: 008B0000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during eeprom size detection error: can't detect eeprom address/size detection phase #3... .................................................. .............. done error: chip layout not detected error: autodetection failed file saved: backup_system_log_7627CA0E_E553_Y1THAIRUARFRBT_E55 3_GPRS_MT6226_S01.01_1.BIN_AF612181_20070915-081423.B0X.bin Finished, time used: 133 sec Remove/Install battery now ! thanks for your help. but what can i do with proplem in eeprom. | |
Help me for 2 chinese phone!! | fra0074 | Chinese Models & Cloned Phones | 4 | 01-25-2008 23:55 |
Help me revive my S65 Please. | g0den99 | S-Gold Based Phones | 14 | 04-14-2005 14:19 |
Help me revive x430 ! | sepia | SYSOL Platform | 1 | 04-03-2005 00:23 |
Help me reviving a BG3 v.12B | simplex | BF, BG, TH, BHx Series | 4 | 11-05-2004 19:59 |
Help me revive Motorola T192 | Bobi | Motorola Old Legacy (EMMI) | 2 | 09-26-2002 18:56 |
