05-22-2009, 08:38 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: KERALA
Member: 609370 Status: Offline Thanks Meter: 13 | help me to select flash file details as below COM6 [VCP0] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A603:0002 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... slowest Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: X225B_PCB01_GPRS_MT6225_S00.BIN ver. sw 2: LBK4J07.7.1.1.0T01M1211_M411A.M, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E40000 Detected eeprom/ffs address is non-standard: 00E40000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E22202200:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E22202200:18E59F00000000 Finalization Done Finished, time used: 62 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! which flash file download from support area? help me thank u |
05-22-2009, 09:11 | #2 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | go to support erea than flash file folder than chainese miracle folder than copy this X225B_PCB01_GPRS_MT6225_S00 and paste in search bar which located in bottom of page than press enter soon u will find ur file if its avilable in server also a sticky thread already avilable |
05-22-2009, 21:43 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! we dont have exactly same firmware on support. you can try similar files which you will find using "X225B_PCB01_GPRS_MT6225_S00" search key. worth to try 3-4-5 files from support |
Help Me To Select Flash File | zonetrichur | Infinity-Box | 1 | 08-15-2008 20:31 |
help me to select flash file | zone2 | Infinity-Box | 1 | 06-26-2008 18:49 |
help me for select flash file | zonetrichur | Infinity-Box | 1 | 05-18-2008 18:09 |
help me for select flash file for CECT P168 | zonetrichur | Infinity-Box | 3 | 02-04-2008 21:12 |
Who can send me or help me to find flash file for GD70 v22A or similar??? | starpho | Panasonic | 0 | 10-05-2001 02:38 |
