Old 02-12-2009, 14:59   #1 (permalink)
Imran Bhatti's Avatar
Member: 266874
Sonork: 100.1581444
Thanks Meter: 97
Thumbs up About Calibration in new updates.
Error in new exe. checked in two mobiles.
COM6 [VCP1] selected
module v2.76
Action: touchscreen calibration
mode: 2
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:EE6F:739A
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: A30E_RX01_01_3.0T09_080422
Version: A96_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 35180800000427
connection Ok
detecting structure #5 (mode-2)...
0 1 2 3 4 5 6 7 8 9error:
detection failed (10 tries)
What to do:
Try another calibration method, if still no luck:
1. make full flash backup for emergency case
2. make "format ffs"
3. Power-On phone
4. Power-Off phone by "Power" button (do NOT remove battery)
5. Repeat "Calibration" operation again
6. if still no luck read full flash and send to support with subject: touchscreen calibration failed
error: can't read required data
error: operation failed !
Finished, time used: 40 sec
Remove/Install battery now !
ok in old exe
19200 autodetect
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
Connecting, wait...
Date: 2005.04.12
Version: 1.0
Version: A96_HW
0 done
44 byte(s) read
connection Ok
0 1 2 3 4 5 6 7 8 9 11 13 14 15 16 17 18 done
150 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 48 sec
Old 02-12-2009, 18:27   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
"Calibration" procedure was changed to make it more stable, some algorithms was moved to other "calibration" mode, so just use other mode(f.e. 4 or 5) instead of mode-2.
Old 02-12-2009, 21:02   #3 (permalink)
taieeb's Avatar
Member: 781262
Thanks Meter: 90
if u are useing with pin finder it does not working just do directly with soldiering rx tx on the board and see works for me more then 20 sets
Old 02-14-2009, 11:56   #4 (permalink)
Member: 266874
Sonork: 100.1581444
Thanks Meter: 97
after all modes which i checked carefully and made this post for those who are facing the problem like this.if both of u have checked the new method plz post here logs from new exe 2.76?
WHAT ABOUT SX4 IN NEW virsion ??? in ATf rajesh_raj Advance-Box 9 03-04-2010 18:39
Old method for CALIBRATION is better than the one in new update rockgsm Infinity-Box 15 08-19-2009 16:04
New Zte Mobile A316G+ Pls Do Add In New Update GsmunlockArena Infinity-Box 73 08-04-2009 06:37
please support new model in new update... BABAK NURI Smart-Clip 1 07-01-2008 07:39
Page generated in 0.16741 seconds with 10 queries
