03-08-2008, 11:04 | #1 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 194285 Status: Offline Thanks Meter: 53 | Bleu 245x Dead NOW DEAD read full flash COM3 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: D:\Program Files\InfinityBox\PModule02\backup_part_1_of_1_200 80308-150159.70X.bin Finished, remove/install battery now ! Time used: 495 sec backup eeprom COM3 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: D:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080308-150401.70E.bin reading... file saved: D:\Program Files\InfinityBox\PModule02\backup_file_system__20 080308-150545.70F.bin Finished, remove/install battery now ! Time used: 127 sec COM3 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: D:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080308-150816.70E.bin Check space Ok Write... Area: Firmware flash: BF7353FFFF0052:00008500000000 Write: Firmware error: no any expected answer error: flash write error: 02000000:00002000 error: no any expected answer error: flash write error: 02000000:00002000 Write failed Finished, remove/install battery now ! Time used: 60 sec COM3 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: D:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080308-151024.70E.bin Check space Ok Write... Area: eeprom flash: BF7353FFFF0052:00008500000000 Write: eeprom error: no any expected answer error: flash write error: 023F2000:00002000 error: no any expected answer error: flash write error: 023F2000:00002000 Write failed Finished, remove/install battery now ! Time used: 66 sec PHONE IS DEAD NOW HELP NEED |
03-08-2008, 13:32 | #2 (permalink) |
Member: 194285 Status: Offline Thanks Meter: 53 | not able to flash any file from support site. that is main, ffs and eeprom also i am not able to write flash back up it showing data error loading fail, probably damageed data file Loading file v.02... Loading failed, probably damaged data file. Loading file v.02... Loading failed, probably damaged data file. Loading file v.02... Loading failed, probably damaged data file. also not able to write eeprom backup file COM3 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: d:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080308-175652.70E.bin Check space Ok Write... Area: eeprom flash: BF7353FFFF0052:00008500000000 Write: eeprom Write Ok Close... Close Ok Restart... Restart Ok Finished, remove/install battery now ! Time used: 16 sec |
03-08-2008, 20:44 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Download latest PModule02 from support area and try again. btw, what was the reason to flash phone ? Unlock function is not released yet for this model, flashing not unlock phone. |
03-10-2008, 15:10 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | As I can see eeprom was written w/o problems. Please, repeat firmware write process. In case of any problems send flash backup to [email protected] and we will prepare file |
07-31-2008, 04:41 | #9 (permalink) | |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Quote:
Ur Correct Infinity Team This Model Is Not Supported..... I Think My Dear@e_motion Has Mistaken...hope...unlocking Of This Model Will Support Soon...br. | |
bleu 245x dead | shashankmobile | ET-BoX | 6 | 01-06-2013 19:26 |
bleu 245x dead after flash. | sunny_gsm | Infinity-Box | 7 | 05-27-2011 18:03 |
bleu-245x dead | veerpreet | Infinity-Box | 1 | 11-26-2008 16:54 |
bleu 245x dead | accurate | Infinity-Box | 0 | 06-30-2008 11:23 |
bleu 245x dead | accurate | Infinity-Box | 0 | 06-25-2008 12:35 |
