01-08-2016, 18:48 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Help me to unlock this MTK MOBILE PHONE It Was asking (Enter Sim ME lock [NP]) then i did SP CODE READER and it gave me wrong code, then i tried SP DIRECT UNLOCK then all was done well but phone still locked, its still asking for code but tried to do Sp unlocking and Phone status on software shows unlocked. Need help here is current logs. Operation : Check / Read Info [ v1.40 ] Code: Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001DC4DB32462BD DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001DC4DB32462BD [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : AG ProdName : AG_Chrome_Mini ProdModel : Chrome Mini Device : Chrome Mini AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1.7 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V47_P16_1_wg_n EXTRA : LCD [0] : ili9488_hvga_dsi_cmd LCD Res : 480x320 TOUCH [0] : ft5206 CAM [0] : gc0328_yuv CAM [1] : gc0311_yuv MODEM : S3507_MOZ_NoEdge_B18_Switch_Lock LOCALE : pt_PT pt_BR en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH mdpi -sw600dp -sw720dp Done! Elapsed: 00:00:11 Reconnect Power/Cable! Mode : Read Codes Code: Operation : SP Unlock [ v1.40 ] Mode : Read Codes 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001DC4DB32462BD DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001DC4DB32462BD [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM [1] codes : [1] Level , [Locked] : False [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False SIM [2] codes : [1] Level , [Locked] : False [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False Done! Elapsed: 00:00:24 Reconnect Power/Cable! Mode : Direct Unlock Code: Operation : SP Unlock [ v1.40 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001DC4DB32462BD DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001DC4DB32462BD [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Lock Status : Not Locked! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
The Following User Says Thank You to johnmadzeka1 For This Useful Post: |
01-09-2016, 10:16 | #3 (permalink) |
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Ok Bro here is file: MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V47_P16_1_wg_n_ eMMC |
The Following 3 Users Say Thank You to johnmadzeka1 For This Useful Post: |
01-16-2016, 06:31 | #8 (permalink) |
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Still Holding on to the Sets, Please update me support Team so I know what to tell Customer and it will be great if you help me. Thanks |
