09-19-2010, 19:21 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Huawei G6600 pinout ????? I had tryed using pin finder, it finds Rx Tx on pins 3 an 4 but phone doesen't boot. I want ot solder wires on pcb but the picture given is diffrent from the phones . Can someone point me on the picture attaced here where is rx and tx on board? |
The Following User Says Thank You to dragosgsm For This Useful Post: |
09-19-2010, 20:53 | #3 (permalink) |
Member: 148032 Status: Offline Thanks Meter: 415 | I know that because I had used search before posting, but I don't have s211 cable so I tryed with pinfider but,as I said,phone dosen't boot(pinfinder findes pins but doesen't boot) Phone is new and pinfinder is workind with other phone models I want like someone to point me on pic atached Rx and TX |
09-19-2010, 21:11 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | three points at right side. 0 0 0 0 ________ 1 2 3 1: connect to RJ45 pin-2 2: connect to RJ45 pin-3 GND - take it from PCB (f.e. from "-" battery contact) |
The Following 10 Users Say Thank You to YellowBoss For This Useful Post: |
01-21-2011, 18:26 | #7 (permalink) |
No Life Poster Join Date: Sep 2006 Location: (¯Catch Me If U Can¯) Age: 50
Member: 360073 Status: Offline Thanks Meter: 2,181 | COM4 [VCP0] selected module v3.73 Action: read unlock codes unlock method: read codes Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2FY01V01.09 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 35751003698294 connection Ok 189 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 Finished, time used: 14 sec Remove/Install battery now ! |
The Following User Says Thank You to MMDEBILI For This Useful Post: |
01-21-2011, 18:50 | #8 (permalink) | |
Member: 360073 Status: Offline Thanks Meter: 2,181 | Quote:
01-22-2011, 14:11 | #9 (permalink) | |
Junior Member Join Date: Nov 2010
Member: 1434518 Status: Offline Thanks Meter: 7 | Quote:
03-31-2011, 13:16 | #12 (permalink) |
Insane Poster Join Date: Oct 2006
Member: 365289 Status: Offline Thanks Meter: 9 | COM5 [VCP0] selected module v3.75 Action: read unlock codes unlock method: read codes Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2RT01V01.04 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 35751003858927 connection Ok 189 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 177 byte(s) read reading data... 972 byte(s) read lock[1] code: + 87362826 lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 17 sec Remove/Install battery now ! |
The Following User Says Thank You to abidjon For This Useful Post: |
04-04-2011, 14:34 | #13 (permalink) |
No Life Poster Join Date: Dec 2005 Location: In My Dreams
Member: 210304 Status: Offline Sonork: 100.1573283 Thanks Meter: 1,455 | Done 100% With v3.82 COM11 [VCP0] selected module v3.82 Action: read unlock codes unlock method: read codes Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2EM01V01.08 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 3575XXXXXXXXX connection Ok 189 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 177 byte(s) read reading data... 972 byte(s) read lock[1] code: + 43487131 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 16 sec Remove/Install battery now ! |
The Following User Says Thank You to SiLver GSM For This Useful Post: |
04-11-2011, 19:22 | #14 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Marocunlocking™
Member: 248858 Status: Offline Sonork: 100.1608346 Thanks Meter: 216 | COM152 [VCP0] selected module v3.82 Action: "sp-unlock" méthode déverrouillage: Smart rapide Modèle: Huawei-G6600 Contrôle des données, attendre ... téléphone doit être éteint! Appuyez et restez appuiez sur le bouton "Power" dès maintenant! 19200 autodetect Initialisation [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... lachez bouton d'alimentation maintenant! Téléphone détecté, attendre ... Matériel: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2FY01V01.09 Version: BYD35_09A_PMWY_HW 82 byte(s) read IMEI: 35751003891387 connexion Ok 189 byte(s) read lecture des données en cours ... reading data #2... la construction de nouvelles données ... écriture de données ... 177 byte(s) read lecture des données en cours ... 972 byte(s) read la construction de nouvelles données ... écriture de données ... verifying... vérification Ok bien Terminé, temps utilisé: 25 sec Retirez / remettre la batterie maintenant! |
The Following User Says Thank You to pikiche For This Useful Post: |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
8810 pinout?? | timitiz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-11-2012 11:10 |
Please Help, Pinout of N8810 | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-30-2010 15:53 |
8810 pinouts for dejan flasher !?!?!? | makona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-03-2001 04:39 |
8850 pinouts | MDR | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 12-30-2000 01:23 |
