12-26-2007, 22:27 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | Help, MG320d Death!!!! COM1 [VCP0] selected Device: LG MG320 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Write: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98004A00000001:FEEA0000000000 flash: Toshiba AMD/Fujitsu std [B 0008x002000 00FFx010000] 16Mb id: 0000527A Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 350305260000001 file saved: backup_eeprom_350305260000001_LG MG320_20071226-161615.B1E.bin ........... version: 724-16 V10a 55 MG320cP64FL Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 98004A00000001:FEEA0000000000 Write: Alchemy data flash: 90009000900090:90909000000000 flash: 90009000900090:90909000000000 error: wrong write first sector at 0x00000000 Write Fail Finished, time used: 253 sec Remove/Install battery now ! some solution tnz in advance.... |
12-27-2007, 15:46 | #3 (permalink) |
Member: 189984 Status: Offline Thanks Meter: 112 | hello... thz for answer... the mobile its working OKK, now try to unlocking and ok, now try to change imei and cant be changed... continues in the orginal imei, now try to flash with differents FW... and the SW given always this error.... |
help 3220 death water no working | Esam from Gaza | Nokia Hardware & Hardware Repair | 1 | 07-31-2009 17:13 |
help u900 death! | talibans | FuriousGold | 5 | 02-20-2009 10:00 |
Help V3E death whit smart clip...!!! | herxxx00 | Smart-Clip | 2 | 05-14-2008 10:28 |
help z240e death after flash | gsm_zone | NSPRO | 2 | 04-01-2008 18:49 |
