02-18-2017, 17:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | HELP...MMX A120 cant backup userdata user data log after 20 min. remove cale Code: Operation : Read UserData [ v1.58 ] Gallery : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847326404050EA1330E7115 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A483847326404050EA1330E7115 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x63002BF5F6A734F1B5B12311F9679498 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processiung : User Photo/Video/Records extraction Trying switch source Fatal error, buffer empty! Phone connection lost??? Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847326404050EA1330E7115 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A483847326404050EA1330E7115 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x63002BF5F6A734F1B5B12311F9679498 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : A106 ProdModel : Micromax A106 Device : A106 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 SECURITY : IMEI_SW [1] : 911391300049922 IMEI_SW [2] : 911391300250421 BTMAC Addr : BCD1D355A180 WiFi MAC : BCD1D354DDFE MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V34_1_wg_n Done! Elapsed: 00:00:10 Reconnect Power/Cable! Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847326404050EA1330E7115 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A483847326404050EA1330E7115 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x63002BF5F6A734F1B5B12311F9679498 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : A106 ProdModel : Micromax A106 Device : A106 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 SECURITY : IMEI_SW [1] : 911391300049922 IMEI_SW [2] : 911391300250421 BTMAC Addr : BCD1D355A180 WiFi MAC : BCD1D354DDFE MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V34_1_wg_n Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
02-19-2017, 16:54 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | http://forum.gsmhosting.com/vbb/f296...guide-2195031/ Read dump then same like here. But you need something, like Rstudio. |
02-19-2017, 17:27 | #4 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Quote:
dear bro. Soon, R-stuido video guide will also be made by me and will post here for users, as ftk imager does not support ispff format.. | |
The Following User Says Thank You to chandanps18 For This Useful Post: |
02-19-2017, 18:02 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Better post stuff with free tools ( free by their nature , not cracked, keygens and rest ). |
