10-14-2009, 17:56 | #2 (permalink) |
No Life Poster Join Date: Dec 2007 Location: INSIDE THIS FLAG
Member: 660737 Status: Offline Thanks Meter: 105 | Download flash file from support area; i mean Firmware; language pack and flex run infinity box shell and choose motorola C261. run to flash tab load Firmware; language pack and flex press flash good luck |
The Following User Says Thank You to unicomtogo For This Useful Post: |
10-14-2009, 21:29 | #3 (permalink) | |
How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software | |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
01-23-2010, 11:34 | #6 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
help moto c261 flash tool | GOLDEN-SHARIF | Motorola P2k | 4 | 08-03-2010 17:55 |
help master c261 moto how to connect rocker dongle | jaymnl | Motorola ODM | 1 | 07-06-2009 07:56 |
moto c261 hangs on moto logo | .:KHALIFA:. | Infinity-Box | 1 | 12-27-2006 21:53 |
moto c261 | expertunlocker | Motorola ODM | 2 | 07-26-2006 22:43 |
Moto C261 lock code!! | dog_baby | Motorola ODM | 0 | 06-30-2006 12:57 |
