09-28-2016, 15:16 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Atleast post logs. Try to Fix Unknown BaseBand with Deep Fix option and also try with other available firmwares. Br. Infinity Box Support Team. |
09-28-2016, 15:47 | #3 (permalink) | |
No Life Poster Join Date: Nov 2012 Location: Lagos Nigeria
Member: 1840260 Status: Offline Thanks Meter: 166 | Quote:
Operation : Fix Unknown BaseBand [ v1.56 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6795 BB_CPU_NME : [MediaTek] Helio[X10]|MT6795_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x92 NAND Flash : NOT INSTALLED eMMC Flash : 15010041575044335200388A49F6B235 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R3DPW [eMMC] : FLASH_CID : 15010041575044335200388A49F6B235 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xB6EFA196CAE1B89F912E16325F270D92 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Step #3 Step #3 ... Ok Reset Done! Done! Elapsed: 00:00:31 Reconnect Power/Cable! | |
09-28-2016, 16:38 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It can be. If you flash FW from same HW revision model or factory one, which is compatible with that HW - then it can be HW. Make reflash. Fix BB. Write good NVM and do factory reset. If no luck - then it not SW. |
