Old 08-03-2016, 04:46   #1 (permalink)
Member: 2346548
Thanks Meter: 36
Help With MT6580 Lockedbootloader Device
hello team
i got device names IQ&T Ifoo T55 hang on logo
Operation : Check / Read Info [ v1.53 ]
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 70010056313030303850161E754772F7
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 80001
[eMMC] : FLASH_CID : 70010056313030303850161E754772F7
[eMMC] : FLASH_LEN : 0x00000001C3000000
[eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB]
DEV RID : 0x4F3BA9D8580FB7188CAEF575D4498460
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : IFoo_T55
ProdName : full_w20e_aw_lj_i7_ifoo
ProdModel : IFoo_T55
Device : w20e_aw_lj_i7_ifoo
AndroidVer: 5.1
MTKxCPU : MT6580
MTKxPRJ : w20e_aw_lj_i7_b1b8_ifoo_t55_v009
SECURITY :
IMEI_SW [1] : 354302070028339
IMEI_SW [2] : 354302070028347
BTMAC Addr : 000046AB164A
WiFi MAC : C4A96262EC27
MODEM :
BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P3_1_wg_n
EXTRA :
LCD [0] : jd9261_qhd_dsi_vdo_lj_i7_auo
LCD [1] : otm9605a_vdo_qhd_w20_lj_i7_tm
LCD [2] : rm68191_qhd_vdo_w20_lj_i7_boe
LCD Res : 960x540
TOUCH [0] : focaltech_new
CAM [0] : STOM_HAL_IMGSENSOR
CAM [1] : =ov5648_mipi_raw
CAM [2] : gc2355_front_mipi_raw
MODEM : w20_band1_band8_co_gps
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:08
Reconnect Power/Cable!
this is the info
cant boot to recovery and cant flash it
cant even factory reset it and cant unlockbootloader
when i try to format it it shows
try flashing it
trying to unlock bootloader
thanks team
waitting for ur respond
Old 08-03-2016, 11:19   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. This devicer seems as with ReadOnly emmc.
Make FlashIC test. In Extra tab.
The Following User Says Thank You to JayDi For This Useful Post:
Old 08-03-2016, 14:00   #3 (permalink)
Member: 2346548
Thanks Meter: 36
hey thanks for ur respond
thats what i got from the test
but do u think its emmc problem or if i can unlock bootloader it will be able to be flashed and formatted?
thanks in advance
Old 08-04-2016, 03:48   #4 (permalink)
JayDi's Avatar
Member: 462970
There is not related to bootloader due phone symptomes. Locked bootloader normally not allow phone boot at all.
Old 08-04-2016, 15:49   #5 (permalink)
Member: 2346548
Thanks Meter: 36
no solution?
first time to see phone like this
Old 08-04-2016, 17:16   #6 (permalink)
JayDi's Avatar
Member: 462970
Sw explained all in log. Seems as eMMC came to ReadOnly state.
Old 08-04-2016, 19:57   #7 (permalink)
Member: 2346548
Thanks Meter: 36
thank u for ur care
thankfull for ur help
Page generated in 0.13443 seconds with 9 queries
